SKETCH_PLANE_PARAM read only
Message 1 of 9
is there a way to set the work plane for an element via the API. Following code doesn't work:
Parameter p = c.get_Parameter(BuiltInParameter.SKETCH_PLANE_PARAM);
if (p != null)
    p.Set(r.Name);
as this parameter is read only. Who knows why?
Any ideas?
Christian
Replies (8)
Message 2 of 9
matthew_taylor
Hi Christian,
Depending on the element type the sketchplane may be governed by the level or the host. See FamilyPlacementType also.
What are you trying to do?
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Message 3 of 9
Hey Matt,
I am in a family document. The element I am trying to set the workplane for is a modelcurve.
public static Result Create(ReferencePlane r, ModelCurve c)
    if (p != null)
        p.Set(r.Name);
        return Result.Succeeded;
    else
        return Result.Failed;
Well you can do it in the UI. Please see image attached.
Christian
Message 4 of 9
matthew_taylor
Hi Christian,
Right.
You could do something line this if you know where you want your curve:
Dim locationCurve As DB.LocationCurve = TryCast(modelCurve.Location, DB.LocationCurve)
Dim startPoint As DB.XYZ = locationCurve.Curve.GetEndPoint(0)
Dim endPoint As DB.XYZ = locationCurve.Curve.GetEndPoint(1)
Dim newCurve As DB.Line = DB.Line.CreateBound( _
New DB.XYZ(startPoint.X, startPoint.Y, startPoint.Z + 1.0), _
New DB.XYZ(endPoint.X, endPoint.Y, endPoint.Z + 1.0)) locationCurve.Curve = newCurve
Or you could use:
 modelCurve.SetGeometryCurve(newCurve, True)
or (I haven't used this one):
    Dim sketchplane As DB.SketchPlane = Nothing 'define your sketch plane here
            modelCurve.SetSketchPlaneAndCurve(sketchPlane, newCurve)
            modelCurve.SketchPlane = sketchplane
-Matt
Cheers,
-Matt
Message 5 of 9
The ModelCurve gets created in the right sketchplane, but is not associated with the workplane. The line sits in the right spot. This is not the issue. I just need to set the work plane. That's all I need.
Revit API developer team: Please make this parameter write accessible.
Christian
Message 6 of 9
matthew_taylor
Christian,
'I've just hard-coded the ref plane id, but you can use a filteredelementcollector to find a specific one.
Dim refPlane As DB.ReferencePlane = TryCast(doc.GetElement(New DB.ElementId(2628)), DB.ReferencePlane)
Dim sketchplane As DB.SketchPlane = DB.SketchPlane.Create(doc, refPlane.Id)
'you may be able to reuse an existing sketchplane instead of creating one. modelCurve.SketchPlane = sketchplane
If the line is on the sketch plane it'll stay in the same place. If not, it'll move.
-Matt
Cheers,
-Matt
Message 7 of 9
When I create the ModelCurve I am already assigning a sketchplane:
ModelCurve hidCurve = famdoc.FamilyCreate.NewModelCurve(hidCurves[i], sk);
Still the workplane is not set and I need to assign. I will do some more testing this afternoon, but the easiest would be: make the parameter writable.
Christian
Message 8 of 9
matthew_taylor
Er, if you already have the sketch plane, then just set it via modelCurve.SketchPlane.
If that doesn't work, it's probably because your line isn't parallel or on the sketch plane. I would imagine that's why it wasn't set in the first place.
Edit: POST CODE.
Cheers,
-Matt
Message 9 of 9
Even though the parameter is read only I think I have a solution now. Quite obvios now, but .....
The SketchPlane.Create() method as three overwrites and one is:
Find the right ReferencePlane, pass the reference of that plane to create a SketchPlane and use this SketchPlane to create your ModelCurve. The ModelCurve will be sitting in the right WorkPlane.
Hope this helps someone. Here the code:
// Get the ReferencePlane by name
ReferencePlane r = Utility.GetRefPlaneByName("Center (Front/Back)", famdoc);
// Take the reference of that plane to create a new SketchPlane SketchPlane sk = SketchPlane.Create(famdoc, r.GetReference());
// Make the ModelCurve or whatever else ModelCurve ElevCurve = famdoc.FamilyCreate.NewModelCurve(ElevCurves[i], sk);
regards
Christian
