Wall reference to dxf lines
Helo everybody! I have this question - Is there any reference between lines in dxf which was used by designer as a template to create walls and this walls?
rosalesduquej
First of all, This does not seem like an API Question, am I correct? if the answer is Yes, Most likely you will not get an answer here.
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
In Case not, please elaborate a bit more what you are trying to do.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
