Wall "Function" Layer References
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
Is it possible to get the references for just the "structure" layers of a wall to only dimension the structure?
One way would be to move the structural elements into the wall's core boundary. However, the way walls are built here in SA requires the brick (structure layer) outside the core, so it wraps around the cavity.
The image below shows the wall buildup as it is currently set up. The core is indicated in red.
In the image below, I have moved the structural elements into the core, allowing the structural faces to be dimensioned, but this set-up will result in incorrect wall end conditions.
