Wall Profile resets
Wall Profile resets
Wall Profile resets
Hi there,
I want to know if the profile of a wall is modified. Manually you can see this, because when a wall profile is changed, the option 'Reset Profile' will be available in the Ribbon.
However I can't find the property or trigger in the API. So my question is, how can inspect a wall with the API and see if the profile of a wall is modified ?
alan.quinn
I understand you have questions about finding the trigger for wall profiles via Revit API. The API is not supported but I found the following links that may be useful.
NewWall with Opening
How to retrieve a wall 's original geometry using Revit API?
Accessing the Exterior Face of a Wall Programmatically
Here's another forum post that may yield some additional information.
Hope this helps and thanks for posting.
Thank you alan,
I have looked at the links and I found some usefull information which are worth giving it a try 🙂
alan.quinn
Good to hear and I'm happy to help out.
Ning_Zhou
after 3 years, still no way to know if the wall is profile edited?
