how to cut building into squres in reivit?
i'm in a project to place sensor in building(ifc file).
Like the image below, I plan to find a parking lot ifc file and put it in revit. Then cut the roof into squares like image below,and place sensor into the squares. I'm totally loss now.I want to ask where could I start ,which language should i use?Java or C#?
jeremytammik
Dear Justinjustin,
Great project, sounds super cool.
First, get a spell checker to run over your questions before submitting them  🙂
Then, get started using the Revit API. Here is one overview of the ample available material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
This same topic came up just recently here on the Revit API discussion forum, and some additional suggestions were made:
http://forums.autodesk.com/t5/revit-api/my-first-attempt-at-c/td-p/5460202
http://thebuildingcoder.typepad.com/blog/2015/01/cloud-accelerator-and-more-revit-stuff.html#3
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks a lot 🙂
I also want to ask if revit can do wireless simulation?
jeremytammik
Dear Justinjustin,
For that question, you should turn to a Revit product related forum, not this API programming forum.
In general, the Revit API supports everything that the user interface and underlying product does, no more, no less.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
