Wall CompoundStructure - Add layers in group named-"Layers Below Wrap"
kailas_dhage
kailas_dhage
Hi All,
I am creating wall definition and want to add layers into "Layers Below Wrap" and also mark then to be wrapped. But by default layers are always added into "Layers Above Wrap" and also I am not able to set them as wrapped.
Please suggest way to achieve this. Following is code snippet being used to create wall definition.
Thanks and Warm Regards,
Kailas Dhage
var document = commandData.Application.ActiveUIDocument.Document;
            var collector = new FilteredElementCollector( document ).OfClass( typeof( WallType ) )
                .ToElements();
            var wallDefsrc=collector.OfType<WallType>()
                .FirstOrDefault( tmpDef => tmpDef.Kind == WallKind.Basic );
            if( wallDefsrc== null )
                return Result.Succeeded;
            using( var trans = new Transaction( document, "create wall def" ) )
                trans.Start();
                var wallDefNew = wallDefSrc.Duplicate( "TestWallDef" ) as WallType;
                if( wallDefNew != null )
                    var compStruct = wallDefNew.GetCompoundStructure();
                    compStruct.EndCap = EndCapCondition.Exterior;
                    compStruct.OpeningWrapping = OpeningWrappingCondition.Exterior;
                    var wallLayers = compStruct.GetLayers();
                    var lc = wallLayers.Count;
                    for( var k = 0; k < lc; k++ )
                        wallLayers.RemoveAt( 0 );
                    var wla1 = new CompoundStructureLayer( 0.25, MaterialFunctionAssignment.Structure, ElementId.InvalidElementId )
                                   LayerCapFlag = true
                    wallLayers.Add( wla1 );
                    var wla2 = new CompoundStructureLayer( 0.125, MaterialFunctionAssignment.Structure, ElementId.InvalidElementId )
                                   LayerCapFlag = true
                    wallLayers.Add( wla2 );
                    var wla3 = new CompoundStructureLayer( 0.0625, MaterialFunctionAssignment.Structure, ElementId.InvalidElementId )
                                   LayerCapFlag = true
                    wallLayers.Add( wla3 );
                    compStruct.SetLayers( wallLayers );
                    wallDefNew.SetCompoundStructure( compStruct );
                trans.Commit();
matthew_taylor
Hi Kailas,
I think you're looking for the SetParticipatesInWrapping function http://www.revitapidocs.com/2017/a0963e2b-4f8c-9117-a0cc-19da424e16d8.htm
and the SetNumberOfShellLayers function http://www.revitapidocs.com/2017/8b8ea4e3-e697-6176-92c0-dc2687723a71.htm
There are examples of their use in the SDK.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
