I have noticed a recurring issue when creating certain families (furniture in this instance), where in that if I create a solid extrusion, constrained to reference planes, and give an edge/edges of that extrusion a void sweep to chamfer the edge, the void sweep sometimes 'unsticks' from the solid geometry when it is moved.
See attached file. The Main leg frame of this family is constrained to a 'Width' parameter, adjusting the distance between the legs - this works fine. The edges of the legs have void sweeps around them, to chamfer the edges for a more detailed look.
When I flex the 'width' parameter, the leg frame adjusts as expected, but the void sweep attached to the edge of the leg frame stay static and removes itself from the leg frame.
Any ideas what I'm doing wrong please?
