Understanding Origin of Sketch Plane
nam_vt
nam_vt
I am testing on GenericModelCreation in SDK Samples.
I tried to create 2 extrusions. One extrusion has SketchPlane with Origin is new XYZ(XYZ.Zero.X, XYZ.Zero.Y, 1000). Another one has SketchPlane with Origin is XYZ.Zero.
I did not see any difference between those extrusions output.
Please help me to understand more about Origin of SketchPlane. How do I get location of a geometry in a family?
Nam.
jeremytammik
Dear Nam,
Thank you for your query.
Your question cannot be answered as it stands, because the results depend on the extrusion parameters.
Every plane is defined by two input data items: an origin point and a normal vector.
https://en.wikipedia.org/wiki/Plane_(geometry)
The origin point is not unique, though.
Any arbitrary point that lies in the plane will give the same result.
A more precise, minimal, concise and canonical way to define a plane is to specify just four numbers: the three coordinates of its normal vector and its distance from the origin.
http://thebuildingcoder.typepad.com/blog/2014/09/planes-projections-and-picking-points.html#10
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
