Visual Studio "The Application is in break mode" when debugging Revit Addin
Mohamed.Elmasri
Mohamed.Elmasri
Hi everyone,
Visual Studio shows "The Application is in break mode" when debugging Revit Addin
The Revit Interface
I used "Revit Addin Wizard 2019" .. Itested the project on another PC ,, It works well
but on my PC it shows the error above !
I cannot debug anything 😥
Thanks in advance !
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Mohamed.Elmasri ,
In Visual Studio,
Go to Debug-->Windows-->Exception Settings-->Managed Debugging assistants-->ContextSwitchDeadlock(Uncheck ContextSwitchDeadlock).
I hope this will help you to solve your issue.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Mohamed.Elmasri
Thanks very very much for reply
the message in the post .. disappear
but when I debug with breakpoint
and Revit still at that view
naveen.kumar.t
Autodesk Support
Autodesk Support
I think the problem is related to Visual studio and not related to Revit.
Simple google search gave me these below links
https://stackoverflow.com/questions/36445717/vs2015-the-breakpoint-will-not-currently-be-hit-no-symb...
https://stackoverflow.com/questions/2155930/how-do-i-remedy-the-the-breakpoint-will-not-currently-be...
Naveen Kumar T
Kennan.Chen
Can you post some of your code? I think there must be some bad code which causes the dead lock.
