ViewSheet number
ViewSheet number
Moustafa_K
Advisor Advisor
ViewSheet number
Moustafa_K
Hi
I tried to change a sheet number via APi through this code:
 Transaction t = new Transaction(m_doc, "Do it");
            t.Start();
            FilteredElementCollector sheets = new FilteredElementCollector(m_doc).OfClass(typeof(ViewSheet));
            foreach (ViewSheet sht in sheets)
                if (sht.SheetNumber.StartsWith("L20-")) sht.SheetNumber = sht.SheetNumber.Replace("L20-", "A");
t.Commit();
and it successfully did the job, unfortunatly it didnot change the SheetView name, Although Changing Sheetnumber through UI is auto change View name. do i miss something?
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
What happens if you try to get the parameter Sheet Number and use Parameter.Set("A")
Moustafa_K
Yes it works. but strange isn't it?
just for clarification for other Collegues Statement should be like this:
  //sht.SheetNumber = sht.SheetNumber.Replace("L20-", "A");  <-- not to use
sht.get_Parameter(BuiltInParameter.SHEET_NUMBER).Set(sht.SheetNumber.Replace("L20-", "A"));
Moustafa Khalil
