ViewSchedule cell style override (border) - help needed
sobon.konrad
sobon.konrad
I have been trying to override the Header section of the schedule with some border styles. I can easily change text properties (underline, italics, bold, text size etc) but cant seem to be able to change the border display/lineweight.
Here's what I am doing:
gStyles = FilteredElementCollector(doc).OfClass(GraphicsStyle).ToElements()
for i in gStyles:
	if i.GraphicsStyleCategory.Name == "veryFatLineStyle":
		lineStyle = i
hsd = tableData.GetSectionData(SectionType.Header)
hsd.SetCellText(hsd.FirstRowNumber, hsd.FirstColumnNumber, "XYZ Schedule")
if hsd.AllowOverrideCellStyle(hsd.FirstRowNumber, hsd.FirstColumnNumber):
	options = TableCellStyleOverrideOptions()
	options.BorderLineStyle = True
	options.BorderBottomLineStyle = True
	options.BorderLeftLineStyle = True
	options.BorderRightLineStyle = True
	options.BorderTopLineStyle = True
	tcs = TableCellStyle()
	tcs.SetCellStyleOverrideOptions(options)
	tcs.BorderBottomLineStyle = lineStyle.Id
	tcs.BorderLeftLineStyle = lineStyle.Id
	tcs.BorderRightLineStyle = lineStyle.Id
	tcs.BorderTopLineStyle = lineStyle.Id
	hsd.SetCellStyle(hsd.FirstRowNumber, hsd.FirstColumnNumber, tcs)
 Can anyone tell me if I am making any mistakes? I am only confused by the BorderLineStyle method present in the TableCellStyleOverrideOptions while its not available in the TableCellStyle class.
Thanks!
rosalesduquej
Hi Konrad.Sobon,
It looks to me that BorderLineStyle indicates if any of the 4 borders are overridden.  And setting this flag sets all 4 border styles to be overridden.
Maybe try setting only BorderLineStyle and then modify the 4 lines that this property will make them avalible to be overridden.
Let me know how it goes.
Best,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
sobon.konrad
Can you please provide a sample code of the solution that you are suggesting? I believe I did try that already and the result was still the same, but just to make sure code would be appreciated. Thanks!
chris
I am experiencing the same issue. Did you find a solution?
sobon.konrad
I am sorry but i didn't and judging by the responses from Autodesk folks they dont know either.
chris
Hi, I know it is possible as I have seen other API's doing what we are trying...
chris.j.mckeown
I have resolved this issue.
instead of:
tcs.BorderBottomLineStyle = styleLines.Id;
use the GraphicsStyleCategory Id:
tcs.BorderBottomLineStyle = styleLines.GraphicsStyleCategory.Id;
Regards
