View Phase Parameters Missing??
MattKincaid
MattKincaid
Our dev team recently encountered a Revit 2017 project file (from a customer) where some of the 3d Views were missing the usual Phase parameters.  Some Views have them, but others do not.  All newly created views (created via the API or the UI) do not have the Phase parameters. Also of note, the Phase dialog in Revit does not show any Phases, and the buttons to add new Phases are disabled.
My understanding was that all Views in a Revit project have a Phase.  Is there an Autodesk supported way to remove the Phase parameters from Views?  Or was this just a corrupt file?
Not strictly an API question.  But it is an issue that is impeding our Addin's use of the API since our code assumes all Views will have a Phase :).  Thanks in advance!
MattKincaid
For the benefit of anyone else who may stumble upon this, it looks to be a known issue that was fixed in 2018.1.  Anyone at the factory care to comment on whether the fix will be pushed back into 2017?
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
