VariesAcrossGroups lost when ReInsert_ing doc.ParameterBindings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Our plugin maintains some instance parameter values across many elements, including those in groups.
Occasionally the end users will introduce data that activates an unused Category,
so we have to update the document parameter bindings, to include those categories.
However, when we call
doc.ParameterBindings.ReInsert()
our existing parameter values inside groups are lost, because our VariesAcrossGroups flag is toggled back to false?
How did Revit intend this to work - are we supposed to use this in a different way, to not trigger this problem?
ReInsert() expects a base Definition argument, and would usualy get an ExternalDefinition supplied.
To learn, I instead tried to scan through the definition-keys of existing bindings and match those.
This way, I got the document's InternalDefinition, and tried calling Reinsert with that instead
(my hope was, that since its existing InternalDefinition DID include VariesAcrossGroups=true, this would help.)
Alas, Reinsert doesn't seem to care.
The problem, as you might guess, is that after VariesAcrossGroups=False, a lot of my instance parameters have collapsed into each other, so they all hold identical values. Given that they are IDs, this is less than ideal.
My current (intended) solution is to instead grab a backup of all existing parameter values BEFORE I update the bindings, then after the binding-update and variesAcrossGroups back to true,
then inspect all values and re-assign all parameter-values that have been broken.
But as you may surmise, this is less than ideal - it will be horribly slow for the users to use our plugin,
and frankly it seems like something the revitAPI should take care of, not the plugin developer.
Are we using this the wrong way?
One approach I have considered, is to bind every possibly category I can think of, up front and once only.
But I'm not sure that is possible. Categories in themselves are also difficult to work with, as you can only create them indirectly, by using your Project-Document as a factory (i.e. you cannot create a category yourself, you can only indirectly ask the Document to - maybe! - create a category for you, that you request). Because of this, I don't think you can bind for all categories up front - some categories only become available in the document, AFTER you have included a given family/type in your project.
To sum it up:
First, I
doc.ParameterBindings.ReInsert() my binding, with the updated categories.
Then, I call InternalDefinition.SetAllowVaryBetweenGroups()
(after having determined IDEF.VariesAcrossGroups has reverted back to false.)
I am interested to hear the best way to do this, without destroying the client's existing data.
Thank you very much in advance.
