Value of overridden dimensions
BCampbellNWL
BCampbellNWL
Im using C# to create some tools, and I was wondering, is it possible to get the value of the "Replace With Text" on dimensions? the idea is to make a tool to identify overridden dimensions to help identify problems in the model.
Thanks!
-Ben
architect.bim
Hi, Benjamin!
Sure you can. Collect the Dimension object. Get its ValueOverride property value if you dimension is single-segment. For multi-segment dimension first get its Segments and use the corresponding property of the DimensionSegment class.
Maxim Stepannikov | Architect, BIM Manager, Instructor
BCampbellNWL
Hey Maxim! Ive grabbed all the dimensions from the current view using the FilteredElementCollector, but I cant seem to be able to grab ValueOverride as a parameter for those elements. Do you know how I would apply it to my elements in a Foreach loop?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @BCampbellNWL ,
Does this help?
FilteredElementCollector collector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Dimensions).WhereElementIsNotElementType();
foreach(Element e in collector)
   if(e is Dimension)
       Dimension dimension = e as Dimension;
       string dimensionTextValue = dimension.ValueOverride;//Get Text Value
       dimension.ValueOverride = "Your Text Value";//Set Text Value
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
BCampbellNWL
That worked perfectly! Thank you!
