Utilizing Native Revit Commands - Navigating Revit Dialogs with the API
rhanzlick
rhanzlick
I am trying to create an External command that will launch the "Visibility/Graphic Overrides for ()" dialog for a view template.
With quite a lot of effort, research, and skimming JournalFiles, I have managed to figure out how to launch the native "Visibility/Graphic Overrides for (ActiveView)" dialog.
I would like to launch the "Visibility/Graphic Overrides for (ViewTemplate)" dialog with the API. Is there a way to do this? See below for a C# example method:
private void LaunchVG_VTDialog(UIApplication uiApp)
    //commandId for Visibility/GraphicsOverride dialog
    string commandId1 = "ID_VIEW_CATEGORY_VISIBILITY";
    uiapp.PostCommand(RevitCommandId.LookupCommandId(commandId1));
franciscopossetto
Hey,
Here are listed all the commands you can execute:
https://www.revitapidocs.com/2020/f6ccdc1b-6ac3-9c49-d0bb-8a7d1877eab0.htm
I think this one is the closest to what you need:
uiApp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.ManageViewTemplates));
But you have to select the template and the V/G option, what is basically the same to select it manually from the UI.
I am not aware if exist another way to do it.
Github:
https://github.com/franpossetto
rhanzlick
Thanks for your response Francis. I was aware of this command, and was
hoping there was a way to skip this (intermediate) step. (ie some way of
modifying these postable commands with some type of options or additional
settings).
Moustafa_K
Does assigning and triggering keyboard shortcuts would help in this case ?
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
rhanzlick
I am open to keyboard shortcuts, just not aware of how one would assign them to this particular window.
Sean_Page
I think this is what you are looking for.
uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.ApplyTemplatePropertiesToCurrentView));
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
