Util.ErrorMsg
Util.ErrorMsg
Util.ErrorMsg
I got the following code from
http://thebuildingcoder.typepad.com/blog/2013/06/family-api-add-in-load-family-and-place-instances.h...
  if( null == family )
    // It is not present, so check for
    // the file to load it from:
    if( !File.Exists( FamilyPath ) )
      Util.ErrorMsg( string.Format(
        "Please ensure that the sample table "
        + "family file '{0}' exists in '{1}'.",
        FamilyName, _family_folder ) );
      return Result.Failed;
    // Load family from file:
    using( Transaction tx = new Transaction( doc ) )
      tx.Start( "Load Family" );
      doc.LoadFamily( FamilyPath, out family );
      tx.Commit();
 SharpDevelop in Revit gives an error when building that it does not know Util.
Should I load a class for this? See the screen shot
Thank you,
Hadi
dante.van.wettum
You forgot part of the sample code. check the Util.cs as well.
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
here you have the method:
 public static void ErrorMsg( string msg )
      Debug.WriteLine( msg );
      WinForms.MessageBox.Show( msg,
        _caption,
        WinForms.MessageBoxButtons.OK,
        WinForms.MessageBoxIcon.Error );
So you can either  implement the Utils class or just change it in your code to something like TaskDialog.show();
Hi.
Thank you for the reply.
I would like to use Util.cs form below so that I can use its other features.
Apparently, I do not know how to use an external class in my code. I made a new class and copied the code but when I tried to build it seems that it is not introduced.
I am still a beginner in using external classes.
I would be grateful if you could guide me on this.
jeremytammik
Change the namespace to be the same.
Read about .NET namespaces before doing anything else:
https://www.tutorialspoint.com/csharp/csharp_namespaces.htm
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you & I will.
