How to set the wall height?
I need export a wall, and then import and create the same wall.
I find the height related parameters are null or readonly, for the parameter which is not readonly, e.g. "Unconnected Height", the result is not the value I set, so how can I set the height of a wall ?
here is my code as below:
[Transaction(TransactionMode.Manual)]
public class CreateWallCmd : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
XYZ pt1 = new XYZ(0, 0, 0);
XYZ pt2 = new XYZ(10, 0, 0);
Line line = Line.CreateBound(pt1, pt2);
Level level= new FilteredElementCollector(doc)
.OfClass(typeof(Level))
.First<Element>(e => e.Name.Equals("Level 1")) as Level;
Transaction act = new Transaction(doc, "Wall.Create");
act.Start();
try
Wall wall = Wall.Create(doc, line, level.Id, true);
Parameter WALL_ATTR_HEIGHT_PARAM = wall.get_Parameter(BuiltInParameter.WALL_ATTR_HEIGHT_PARAM);
if (WALL_ATTR_HEIGHT_PARAM != null)
if (!WALL_ATTR_HEIGHT_PARAM.IsReadOnly)
WALL_ATTR_HEIGHT_PARAM.Set(100);
Parameter WALL_BASE_HEIGHT_PARAM = wall.get_Parameter(BuiltInParameter.WALL_BASE_HEIGHT_PARAM);
if (WALL_BASE_HEIGHT_PARAM != null)
if (!WALL_BASE_HEIGHT_PARAM.IsReadOnly)
WALL_BASE_HEIGHT_PARAM.Set(100);
Parameter WALL_BASE_OFFSET = wall.get_Parameter(BuiltInParameter.WALL_BASE_OFFSET);
if (WALL_BASE_OFFSET != null)
if (!WALL_BASE_OFFSET.IsReadOnly)
WALL_BASE_OFFSET.Set(50);
Parameter WALL_TOP_OFFSET = wall.get_Parameter(BuiltInParameter.WALL_TOP_OFFSET);
if (WALL_TOP_OFFSET != null)
if (!WALL_TOP_OFFSET.IsReadOnly)
WALL_TOP_OFFSET.Set(100);
IList<Parameter> UnconnectedHeigth_Params = wall.GetParameters("Unconnected Height");
if (UnconnectedHeigth_Params.Count > 0)
if (!UnconnectedHeigth_Params[0].IsReadOnly)
// can set, but the result is not 100
UnconnectedHeigth_Params[0].Set(100);
catch (System.Exception e)
TaskDialog.Show("Exception", e.Message);
act.Commit();
return Result.Succeeded;
thannaingoo.api
You can try with below code for walls creation.  You can set the height directly.
http://www.revitapidocs.com/2015/0ce4c555-4cee-f5fd-2e84-43cacf34ac5c.htm
public static Wall Create(
	Document document,
	Curve curve,
	ElementId wallTypeId,
	ElementId levelId,
	double height,
	double offset,
	bool flip,
	bool structural
Please refer the below link for walls creation. We can find a lot of solution in thebuildingcoder.
http://thebuildingcoder.typepad.com/blog/2017/11/automatic-wall-creation.html
Eden Oo
zhong_wu
Autodesk Support
Autodesk Support
Firstly, I just checked your code and run it on my side, it seems good to set the offset & height correctly to the new created wall, please see the following screenshot as I got.
Create a wallCreate a wallAlso, there are some other parameters you can use to set the height in different way, for example, set the top constraint by "WALL_HEIGHT_TYPE" to any level, and set the top offset with "WALL_TOP_OFFSET".
Check the API doc at http://www.revitapidocs.com/2018.1/3ef7e31c-b41b-c8cc-2713-8f098954613d.htm for details.
John Wu
Developer Technical Services
Autodesk Developer Network
Thank you for your reply.
I can set the height of the wall now, but the result puzzle me a little. That is, I set the height to 100 in VS, but the result is 30480 in revit. screenshot attached as below. 11.png22.png
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
In code what you are giving is in feet (i.e)100 feet
but in Revit it is showing the units in millimeter(mm).
If you want everything in feet you can change the unit settings in Revit
Naveen Kumar T
Got it, thank you very much !
