Using multiplication and division signs
BenoitE&A
BenoitE&A
I just came through a weird result :
I tested the line :
myMessage += "\n Essai priorisation signes " + (1 / 2 * 4) + " essai 2 " + (4 / 2);
Normally this should return 2 for each of the results, right ?
It doesn't. It returns 0 and 2, and the same when you use it in pieces of code.
Could anybody explain me why ?
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
jeremytammik
Dear Benoit,
Thank you for your query.
What is the context, please?
Is this in C# code?
If so, am I correct in assuming it has nothing specific whatsoever to do with the Revit API?
Apparently, the numbers you entered are being handled as integer terms and then converted to strings.
I would have expected an error message on compilation.
The result (4 / 2) --> 2 should not come as a huge surprise.
The first term can be interpreted as (1 / 2) * 4. Using integer arithmetic, the result is obviously 0 * 4 = 0.
It can also be interpreted as 1 / (2 * 4). Using integer arithmetic, the result is again obviously 1/8 --> 0.
So, I wonder why you are asking.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
BenoitE&A
Hi Jeremy,
Yes I use C#. To get you understand the whole idea here is my piece of code :
monMur is a wall and contour is a Curve in the main Plane (in fact it is a portion of one of the faces of the wall monMur)
// Find the offset vector at the middle of the curve
                        XYZ milieu = contour.Evaluate(0.5, true);
                        IntersectionResult ir = locMur.Project(milieu);
                        XYZ vectOffset = ir.XYZPoint - milieu;
                        // Add 1/2 width of current wall to vectOffset
                        XYZ vectOffset = vectOffset * (vectOffset.GetLength() + monMur.WallType.Width/2) / vectOffset.GetLength();
But this code gives a very different result as the following if I change the last line :
                        XYZ vectOffset = vectOffset * (vectOffset.GetLength() + 1/2*monMur.WallType.Width) / vectOffset.GetLength();
Because in this line the term 1/2*monMur.WallType.Width is evaluated as 0 by Revit.
So I Wonder where this comes from...
Benoit
Benoit FAVRE
aignatovich
Hi!
Do not blame Revit, it is innocent :). Read about how number constants are presented in .Net.
Hint: the result is absolutely different from 1 / 2 and 1.0 / 2 or 1 / 2.0
BenoitE&A
Thanks Aignatovitch.
Indeed it can only comes from the way C# deals with numbers. I should get the habbit of coding 1.0 instead of 1 when using numbers.
Still it is... annoying...
Thanks anyway and sorry for the stupid question.
Benoit
Benoit FAVRE
aignatovich
Don't worry.
This behavior is described in standards and it is practically the same in all C-styled languages. It is also good to avoid use of "magic constants" in the code, the better way is to define named constants (const double halfWidth = 0.5;) or just use 0.5*wall.Width*XYZ... in such simple case (but only if the case is really simple)
