I am currently working on a project in Revit and need to place mechanical fabrication hangers at specific points within the model. However, these parts cannot be used as family symbols.
// Collect all ducts
FilteredElementCollector ductshanger = new FilteredElementCollector(doc)
.OfCategory(BuiltInCategory.OST_FabricationHangers)
.WhereElementIsNotElementType();
// Initialize a list to store hanger names
List<string> hangerNames = new List<string>();
foreach (Element item in ductshanger)
FamilySymbol hangerSymbol2 = item as FamilySymbol;
TaskDialog.Show("Fabrication Hangers", $"Hanger :\n{hangerSymbol2 != null}");
if (hangerSymbol2 != null)
// Add the hanger name to the list
hangerNames.Add(hangerSymbol2.Name);
I used the task.dialog and the result was false.
Could you provide guidance or suggest an alternative approach?
Thank you in advance for your assistance.
Solved by jeremy_tammik. Go to Solution.
You cannot place fabrication parts in the same manner as family instances.
You can use the FabricationPart.CreateHanger method:
Its use is demonstrated by the FabricationPartLayout SDK sample.
hi @jeremy_tammik thank you for your reply,
I was just wondering is do you have any sample of using create hanger in some codes?
Yes. Look at the official Revit SDK samples. FabricationPartLayout is your man.
@jeremy_tammik Thank you, I checked those samples, but another problem is when I want to select my fabrication services it doesn't find it, while the item exists in the project.
// Step 1: Collect all Fabrication Parts in the project
FilteredElementCollector collector = new FilteredElementCollector(doc)
.OfClass(typeof(FabricationService));
// Step 4: Display the message in a TaskDialog
TaskDialog.Show("Fabrication Services", "f" + collector.Count());
// Assuming Services is initialized elsewhere or modify it here
FabricationService sb = Services?.FirstOrDefault(x => x.Name.Contains("(500PA)"));
if (sb == null)
TaskDialog.Show("Error", " FabricationService not found.");
return Result.Failed;
Hello, @jeremy_tammik . I tried to edit my code based on the sdk .
but when i select my hanger to placed the erorr that i faced in revit is "Please use FabricationPart.CreateHanger to create fabrication hanger.
Parameter name: button"
// Access the Fabrication Configuration
FabricationConfiguration config = FabricationConfiguration.GetFabricationConfiguration(doc);
if (config == null)
message = "Cannot retrieve the fabrication configuration.";
m_services = config.GetAllLoadedServices();
if (m_services.Count == 0)
// Get the FabricationService associated with the selected FabricationPart
int serviceId = part.ServiceId;
FabricationService partService = config.GetService(serviceId);
if (partService == null)
message = "Cannot retrieve fabrication service for the selected part.";
// Locate the required service button
FabricationServiceButton sbButton = LocateButton(partService, 4, "Strut Hanger");
if (sbButton == null)
message = "The required button was not found in the selected service.";
FabricationPart pt_rectStraight1 = CreateStraightPart(sbButton, 0, viewLevel.Id, 15.0);
if (pt_rectStraight1 == null)
message = "Failed to create hanger part.";
trans.RollBack();
Connector conn1_straight1 = GetPrimaryConnector(pt_rectStraight1.ConnectorManager);
FabricationPart.CreateHanger(doc, sbButton, element.Id, conn1_straight1, 5.0, true);
I really appreciated that give me about about it.
