Using Extrusion to simulate a seal
dirk.neethling
dirk.neethling
I want to insert a groove into the edges of a segmented tunnel element. Into the groove a seal will be embedded.
I am using FamilyInstances as tunnel segments.
The groove can be produced through Extrusion. This Extrusion can then be swept along the edges using an Arc.
That's the idea.
I am struggling to get the example in "Creating and Inserting an Extrusion Family" to work:
http://thebuildingcoder.typepad.com/blog/2011/06/creating-and-inserting-an-extrusion-family.html
Specifically,
Document fdoc = app.NewFamilyDocument(
    templateFileName );
what is templateFileName?
Using this post, I think it should then be possible to insert a seal into this groove:
http://thebuildingcoder.typepad.com/files/cp4011_conover.pdf
Is there a better way?
dirk
dirk.neethling
I am closing this, since Revitalizer helped me to create this in a Project doc using
DirectShape.CreateElement
Hi Dirk,
I know you have closed this but would it be possible to post a picture of the tunnel Segment with the groove.
Have you managed to place the groove on all 4 sides of the segement? I have not been able to achieve this using any modelling techniques never mind using the API.
regards,
Fearg
