- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi.
My question is I use revitnet.dll to copy the element from Document 1 to Document 2 in an external application, and then save Document 2 as Document 3. When I open Document 3, I cannot see the generated element, but if I use addin the way I do, I will get the correct results. not all documents will experience this error.
When I search for this ID in revit (id is 225857), after clicking "show", prompt "no good view could be found". after clicking "ok", only one dimension line can be seen. What could be the reason for this
revit version: 2019
thanks
