UserMEP Calculation Addin
Message 1 of 27
I've followed the article in the following link http://thebuildingcoder.typepad.com/blog/2013/07/user-mep-calculation-sample.html , built and installed the addin and came up with the error messages below:
The DLL's and the addin are in the "Addins" folder along with the default MEPCalculation folder.
Any input would be greatly appreciated.
Replies (26)
Message 21 of 27
IslamSakr
Exactly, i need to do the changes as shown in this print screen and develop the .dll file and .addin file because i can't, can you do it for me?!, sending those 2 files.
Thank you
Message 22 of 27
jeremytammik
If you are looking for someone to do the work for you, please contact Autodesk Consulting or the other developers here in the forum and elsewhere.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 23 of 27
IslamSakr
Actually it is not for me personally, it's for the major of Autodesk users. It will fix what is already exist in Autodesk software (Revit). It doesn't make sense that 1 Lavatory of 1 FU connected to flush valve system give me a flow of 15 gpm !!!
Message 24 of 27
jeremytammik
Please submit a wish fir this functionality in the Revit Idea station and ensure that it gets many votes. Thank you!
Jeremy Tammik
The Building Coder
Message 25 of 27
m.krezolek
I created my own version of PlumbingFixtureFlowServer which is exactly the same as the sample provided by Jeremy.
I have noticed one thing, that when I switch from the default "Plumbing Fixture Flow" calculation method based on the 2021 International Plumbing Code:
the calculations at the piping system level are not being performed:
In my solution, I have only registered the new PlumbingFixtureFlowServer and no PipePressureDropServer as these already exist in Revit by default.
Is this a potential bug or am I missing something?
The flow conversion and pressure drop calculations at a single pipe work as expected and the system is set up correctly i.e. no open ends, correct flow direction etc.
Any suggestions?
Message 26 of 27
luis3461580
Hello, I'm new at this. I would like to install this addin to revit but I don't know if it could help me by indicating the specific location and what I should change. greetings from Bolivia
Message 27 of 27
luis3461580
Hi, I'm new to this, I'm a student from Bolivia. I would like to install this addin UserMepCalculation to revit but I don't know if it could help me by indicating the specific location and what should I change if a video could be made it would be very helpful. greetings and grateful
