MEP Calculation Addin
Is the full source code for RevitMEP 2014 available? If so, where is it located?
arnostlobel
I do not believe the source code for Revit (any Revit) is public domain. Out of curiosity, what would you do with it? 🙂 Debugging, I suppose?
Arnošt Löbel
Sr. Principal Engineer
Autodesk, Revit R&D
Arnošt Löbel
jeremytammik
Dear Deubanks7525,
Thank you for your query.
In fact, in this specific case, an exception was made, since we really do want to enable customisation of this feature.
The code for the Revit MEP Calculation is provided as part of the product installation. In my Revit 2014 installation, it is located here:
C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation
I have not yet installed Revit MEP 2015 or Revit Onepbox 2015, so I cannot say whether it changed.
The source code for Revit 2014 has been cleaned up, refactored to provide a custom MEP calculation replacement add-in, and published on GitHub:
http://thebuildingcoder.typepad.com/blog/2013/07/user-mep-calculation-sample.html
http://thebuildingcoder.typepad.com/blog/2013/11/user-mep-calculation-sample-on-github.html
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
