User MEP calculation, determine if pipe is branch
I've been tryng to implement the spanish Code for the Domestic Cold Water flow calculation. UNE 149201:2017
This code is similar to other European codes as it uses formulas for the calculation of simultaneous flow.
Building Type
Qt > 20l/s
Qt <= 20l/s
If all Qmin < 0.5 l/s
If any Qmin >= 0.5 l/s
Qt >= 1 l/s
Qt > 1 l/s
Flats
Qc = 1.7 * (Qt)0.21 – 0.7
Qc = 0.682 * (Qt)0.45 - 0.14
Qc = Qt
Office, Train station, Airport
Qc = 0.4 * (Qt)0.54 + 0.48
Hotel, clubs, museums
Qc = 1.08 * (Qt)0.5 – 1.83
Qc = 0.698 * (Qt)0.5 – 0.12
Qc = Qt
Qc = (Qt)0.366
Malls
Qc = 4.3 * (Qt)0.27 – 6.65
Hospitals
Qc = 0.25 * (Qt)0.65 + 1.25
Building Type
Qt > 20l/s
Qt <= 20l/s
Qt < 1.5 l/s
Qt >= 1.5 l/s
Schools, Gyms
Qc = -22.5 * (Qt)-0.5 + 11.5
Qc = Qt
Qc = 4.4 * (Qt)0.27 - 3.41
Where:
Qmin: is the Plumbing Fixture Flow
Qt: is the installed flow (The sum of the dependent Qmin flows)
Qc: the simultaneous flow or the calculated
I've got the User Mep Calculation and created my own Flow Server and modified the private double presetFlow for a Flat Building as follows
        private double presetFlow(double dDimensionFlow)
            dDimensionFlow = ConverGPM2LPS(dDimensionFlow);
            double dFlow = 0;
            //double dFlowMin = 0.1; //value in l/s
            //Edificio Viviendas
            if (dDimensionFlow > 20) //Qt > 20 l/s => Qc = 1.7 * Qt^0.21 - 0.7
                dFlow = 1.7 * Math.Pow(dDimensionFlow, 0.21) - 0.7;
            else
                if (dDimensionFlow < 0.5) //Qmin < 0.5 => Qc = 0.682 * Qt^0.45 - 0.14
                    dFlow = 0.682 * Math.Pow(dDimensionFlow, 0.45) - 0.14;
                else
                    if (dDimensionFlow > 1) //Qt > 20 l/s => Qc = 1.7 * Qt^0.21 - 0.7
                    else
                        dFlow = dDimensionFlow;
            //if (sectionIsMain(PipingSystem ps))
            //    dFlow = dDimensionFlow;
            return ConvertLPS2GPM(dFlow);
        private double ConvertLPS2GPM(double lpsValue)
            double cvrt = lpsValue * 15.850372483753;
            return cvrt;
        private double ConverGPM2LPS(double gpmvalue)
            double cvrt = gpmvalue * 0.06309;
            return cvrt;
This method doesn't know if it's calculating a Main or a Branch so it's applying the formula to all terminal sections.
It shouldn't apply any simultaneity to terminals.
Is there any way of extracting from the PipePlumbingFixtureFlowData the section of the pipe and validate if isMain()?
Here you have the entire code I'm using:
// (C) Copyright 2003-2012 by Autodesk, Inc.
// Permission to use, copy, modify, and distribute this software in
// object code form for any purpose and without fee is hereby granted,
// provided that the above copyright notice appears in all copies and
// that both that copyright notice and the limited warranty and
// restricted rights notice below appear in all supporting
// documentation.
// AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
// AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
// MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
// DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
// UNINTERRUPTED OR ERROR FREE.
// Use, duplication, or disclosure by the U.S. Government is subject to
// restrictions set forth in FAR 52.227-19 (Commercial Computer
// Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
// (Rights in Technical Data and Computer Software), as applicable.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Resources;
using Autodesk.Revit;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.ExternalService;
using Autodesk.Revit.ApplicationServices;
namespace PGIStraightSegmentCalculationServers.Pipe
    /// <summary>
    /// The external server that calculates the plumbing fixture flow.
    /// </summary>
    public class PlumbingFixtureFlowServerViviendas : IPipePlumbingFixtureFlowServer
        System.Collections.Generic.ICollection<KeyValuePair<double, double>> flushTanks = new System.Collections.Generic.Dictionary<double, double>();
        System.Collections.Generic.ICollection<KeyValuePair<double, double>> flushValves = new System.Collections.Generic.Dictionary<double, double>();
        private void initilizeflushTanks()
            if (flushTanks.Count > 0)
                return;
            //the key is Fixture Units
            //the value is Flow (gallon (U.S.) per minute (gpm) (gal/min))
            flushTanks.Add(new KeyValuePair<double, double>(1, 3.0));
            flushTanks.Add(new KeyValuePair<double, double>(2, 5.0));
            flushTanks.Add(new KeyValuePair<double, double>(3, 6.5));
            flushTanks.Add(new KeyValuePair<double, double>(4, 8.0));
            flushTanks.Add(new KeyValuePair<double, double>(5, 9.4));
            flushTanks.Add(new KeyValuePair<double, double>(6, 10.7));
            flushTanks.Add(new KeyValuePair<double, double>(7, 11.8));
            flushTanks.Add(new KeyValuePair<double, double>(8, 12.8));
            flushTanks.Add(new KeyValuePair<double, double>(9, 13.7));
            flushTanks.Add(new KeyValuePair<double, double>(10, 14.6));
            flushTanks.Add(new KeyValuePair<double, double>(11, 15.4));
            flushTanks.Add(new KeyValuePair<double, double>(12, 16.0));
            flushTanks.Add(new KeyValuePair<double, double>(13, 16.5));
            flushTanks.Add(new KeyValuePair<double, double>(14, 17.0));
            flushTanks.Add(new KeyValuePair<double, double>(15, 17.5));
            flushTanks.Add(new KeyValuePair<double, double>(16, 18.0));
            flushTanks.Add(new KeyValuePair<double, double>(17, 18.4));
            flushTanks.Add(new KeyValuePair<double, double>(18, 18.8));
            flushTanks.Add(new KeyValuePair<double, double>(19, 19.2));
            flushTanks.Add(new KeyValuePair<double, double>(20, 19.6));
            flushTanks.Add(new KeyValuePair<double, double>(25, 21.5));
            flushTanks.Add(new KeyValuePair<double, double>(30, 23.3));
            flushTanks.Add(new KeyValuePair<double, double>(35, 24.9));
            flushTanks.Add(new KeyValuePair<double, double>(40, 26.3));
            flushTanks.Add(new KeyValuePair<double, double>(45, 27.7));
            flushTanks.Add(new KeyValuePair<double, double>(50, 29.1));
            flushTanks.Add(new KeyValuePair<double, double>(60, 32.0));
            flushTanks.Add(new KeyValuePair<double, double>(70, 35.0));
            flushTanks.Add(new KeyValuePair<double, double>(80, 38.0));
            flushTanks.Add(new KeyValuePair<double, double>(90, 41.0));
            flushTanks.Add(new KeyValuePair<double, double>(100, 43.5));
            flushTanks.Add(new KeyValuePair<double, double>(120, 48.0));
            flushTanks.Add(new KeyValuePair<double, double>(140, 52.5));
            flushTanks.Add(new KeyValuePair<double, double>(160, 57.0));
            flushTanks.Add(new KeyValuePair<double, double>(180, 61.0));
            flushTanks.Add(new KeyValuePair<double, double>(200, 65.0));
            flushTanks.Add(new KeyValuePair<double, double>(225, 70.0));
            flushTanks.Add(new KeyValuePair<double, double>(250, 75.0));
            flushTanks.Add(new KeyValuePair<double, double>(275, 80.0));
            flushTanks.Add(new KeyValuePair<double, double>(300, 85.0));
            flushTanks.Add(new KeyValuePair<double, double>(400, 105.0));
            flushTanks.Add(new KeyValuePair<double, double>(500, 124.0));
            flushTanks.Add(new KeyValuePair<double, double>(750, 170.0));
            flushTanks.Add(new KeyValuePair<double, double>(1000, 208.0));
            flushTanks.Add(new KeyValuePair<double, double>(1250, 239.0));
            flushTanks.Add(new KeyValuePair<double, double>(1500, 269.0));
            flushTanks.Add(new KeyValuePair<double, double>(1750, 297.0));
            flushTanks.Add(new KeyValuePair<double, double>(2000, 325.0));
            flushTanks.Add(new KeyValuePair<double, double>(2500, 380.0));
            flushTanks.Add(new KeyValuePair<double, double>(3000, 433.0));
            flushTanks.Add(new KeyValuePair<double, double>(4000, 525.0));
            flushTanks.Add(new KeyValuePair<double, double>(5000, 593.0));
        private void initilizeflushValves()
            if (flushValves.Count > 0)
                return;
            flushValves.Add(new KeyValuePair<double, double>(5, 15.0));
            flushValves.Add(new KeyValuePair<double, double>(6, 17.4));
            flushValves.Add(new KeyValuePair<double, double>(7, 19.8));
            flushValves.Add(new KeyValuePair<double, double>(8, 22.2));
            flushValves.Add(new KeyValuePair<double, double>(9, 24.6));
            flushValves.Add(new KeyValuePair<double, double>(10, 27.0));
            flushValves.Add(new KeyValuePair<double, double>(11, 27.8));
            flushValves.Add(new KeyValuePair<double, double>(12, 28.6));
            flushValves.Add(new KeyValuePair<double, double>(13, 29.4));
            flushValves.Add(new KeyValuePair<double, double>(14, 30.2));
            flushValves.Add(new KeyValuePair<double, double>(15, 31.0));
            flushValves.Add(new KeyValuePair<double, double>(16, 31.8));
            flushValves.Add(new KeyValuePair<double, double>(17, 32.6));
            flushValves.Add(new KeyValuePair<double, double>(18, 33.4));
            flushValves.Add(new KeyValuePair<double, double>(19, 34.2));
            flushValves.Add(new KeyValuePair<double, double>(20, 35.0));
            flushValves.Add(new KeyValuePair<double, double>(25, 38.0));
            flushValves.Add(new KeyValuePair<double, double>(30, 42.0));
            flushValves.Add(new KeyValuePair<double, double>(35, 44.0));
            flushValves.Add(new KeyValuePair<double, double>(40, 46.0));
            flushValves.Add(new KeyValuePair<double, double>(45, 48.0));
            flushValves.Add(new KeyValuePair<double, double>(50, 50.0));
            flushValves.Add(new KeyValuePair<double, double>(60, 54.0));
            flushValves.Add(new KeyValuePair<double, double>(70, 58.0));
            flushValves.Add(new KeyValuePair<double, double>(80, 61.2));
            flushValves.Add(new KeyValuePair<double, double>(90, 64.3));
            flushValves.Add(new KeyValuePair<double, double>(100, 67.5));
            flushValves.Add(new KeyValuePair<double, double>(120, 73.0));
            flushValves.Add(new KeyValuePair<double, double>(140, 77.0));
            flushValves.Add(new KeyValuePair<double, double>(160, 81.0));
            flushValves.Add(new KeyValuePair<double, double>(180, 85.5));
            flushValves.Add(new KeyValuePair<double, double>(200, 90.0));
            flushValves.Add(new KeyValuePair<double, double>(225, 95.5));
            flushValves.Add(new KeyValuePair<double, double>(250, 101.0));
            flushValves.Add(new KeyValuePair<double, double>(275, 104.5));
            flushValves.Add(new KeyValuePair<double, double>(300, 108.0));
            flushValves.Add(new KeyValuePair<double, double>(400, 127.0));
            flushValves.Add(new KeyValuePair<double, double>(500, 143.0));
            flushValves.Add(new KeyValuePair<double, double>(750, 177.0));
            flushValves.Add(new KeyValuePair<double, double>(1000, 208.0));
            flushValves.Add(new KeyValuePair<double, double>(1250, 239.0));
            flushValves.Add(new KeyValuePair<double, double>(1500, 269.0));
            flushValves.Add(new KeyValuePair<double, double>(1750, 297.0));
            flushValves.Add(new KeyValuePair<double, double>(2000, 325.0));
            flushValves.Add(new KeyValuePair<double, double>(2500, 380.0));
            flushValves.Add(new KeyValuePair<double, double>(3000, 433.0));
            flushValves.Add(new KeyValuePair<double, double>(4000, 525.0));
            flushValves.Add(new KeyValuePair<double, double>(5000, 593.0));
        private bool AlmostZero(double val)
            return System.Math.Abs(val) < double.Epsilon;
        ///// <summary>
        ///// Calculate the flow with the dimension flow (GPM - gallon (U.S.) per minute (gpm) (gal/min) ) .
        ///// </summary>
        ///// <param name="data">
        ///// The input for the flow calculation. The result flow is also return through the data to the caller.
        ///// </param>
        ///// Return Value: Flow - the units is GPM (gallon (U.S.) per minute (gpm) (gal/min))
        //private double presetFlow( double dDimensionFlow )
        //  return dDimensionFlow;
        /// <summary>
        /// </summary>
        /// </param>
            double dFlow = 0;
            else
                else
                    else
            return cvrt;
            return cvrt;
        /// <summary>
        /// Calculate the flow with the fixture units and flow conversion mode - need to read the table(flushValves and flushTanks) .
        /// </summary>
        /// </param>
        private double getFlowFromFixtureUnits(double dFixtureUnits, FlowConversionMode eFlowConversionMode)
            if ((dFixtureUnits < 0) || AlmostZero(dFixtureUnits))
                return 0;
            initilizeflushTanks();
            initilizeflushValves();
            System.Collections.Generic.ICollection<KeyValuePair<double, double>> points = flushTanks;
            int size = flushTanks.Count;
            double dFlow = 0;
            if (eFlowConversionMode == FlowConversionMode.Valves)
                points = flushValves;
                size = flushValves.Count;
            else if (eFlowConversionMode == FlowConversionMode.Tanks)
            else
                return dFlow;
            if (dFixtureUnits < points.ElementAt(0).Key)
                dFlow = points.ElementAt(0).Value;
            else
                bool bInTable = false;
                int ii = 0;
                for (; ii < size; ii++)
                    if (dFixtureUnits <= points.ElementAt(ii).Key)
                        bInTable = true;
                        break;
                KeyValuePair<double, double> p1, p2;
                if (bInTable)
                    p1 = points.ElementAt(ii);
                    if (ii == 0)
                        p2 = points.ElementAt(ii + 1);
                    else
                        p2 = points.ElementAt(ii - 1);
                else
                    p1 = points.ElementAt(size - 2);
                    p2 = points.ElementAt(size - 1);
                double x1 = p1.Key;
                double y1 = p1.Value;
                double x2 = p2.Key;
                double y2 = p2.Value;
                double x = dFixtureUnits;
                double y = (x * y2 - x1 * y2 + x2 * y1 - x * y1) / (x2 - x1);
                dFlow = y;
            return dFlow;
        /// <summary>
        /// Calculate the flow with the input data .
        /// </summary>
        /// </param>
        public void Calculate(PipePlumbingFixtureFlowData data)
            double dResult = 0.0;
            //The flow configuration mode of the pipe: -1: invalid;  0: Preset; 1: Fixture Units
            if (data.FlowConfiguration == PipeFlowConfigurationType.Preset)
                dResult = presetFlow(data.DimensionFlow);
            else if (data.FlowConfiguration == PipeFlowConfigurationType.Demand)
                dResult = getFlowFromFixtureUnits(data.FixtureUnits, data.FlowConversionMode);
            data.Flow = dResult;
        /// <summary>
        /// Return the method's name this server implements.
        /// </summary>
        public string GetMethodName()
            return Properties.Resources.PlumbingFixtureFlowMethodName;
        /// <summary>
        /// Return the Id of the server.
        /// </summary>
        public System.Guid GetServerId()
            return new Guid("56121D7D-E1D7-42A3-BED8-F4D1D3205833");
        /// <summary>
        /// Return the Id of the service that the sever belongs to.
        /// </summary>
        public ExternalServiceId GetServiceId()
            return ExternalServices.BuiltInExternalServices.PipePlumbingFixtureFlowService;
        /// <summary>
        /// Return the server's name.
        /// </summary>
        public System.String GetName()
            return Properties.Resources.PlumbingFixtureFlowServerNameViviendas;
        /// <summary>
        /// Return the server's vendor Id.
        /// </summary>
        public System.String GetVendorId()
            return "PGI";
        /// <summary>
        /// Return the description of the server.
        /// </summary>
        public System.String GetDescription()
            return Properties.Resources.PlumbingFixtureFlowServerDescription;
        /// <summary>
        /// Return the link of the server information.
        /// </summary>
        public System.String GetInformationLink()
            return Properties.Resources.PlumbingFixtureFlowServerInformationLink;
        //  /// <summary>
        //  /// Return the server description in RTF format.
        //  /// </summary>
        //  public System.String GetRTFDescription()
        //    return Properties.Resources.PlumbingFixtureFlowServerDescriptionRTF;
        /// <summary>
        /// Return the server description in HTML format.
        /// </summary>
        public System.String GetHtmlDescription()
            return "HTML description of plumbing fixture flow server";
        //private bool sectionIsMain(PipingSystem ps)
        //    bool foundMain = false;
        //    for (int i = 0; i < ps.SectionsCount; i++)
        //        MEPSection ms = ps.GetSectionByIndex(i);
        //        if (ms.IsMain(i))
        //            foundMain = true;
        //    return foundMain;
JimJia
Dear Andrei,
I'm communicating with engineering team on this, will keep you updated on any progress.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
JimJia
Dear Andrei, I'm forwarding messages from engineering team, can you help to clarify? "I don’t recall anything about Revit having any logic regarding mains vs. branches from the UI standpoint. Is there something that leads this developer to believe that there is? Looking briefly at the code, seems it would be a simple task to valid from the dev/code side if is use of MEPSection is a valid class, and if that class has a method called isMain()."
Jim Jia
I've been working a little bit more on this and I find that the solution goes through determining if in the System predominates Flash Valves or Flash Tanks.
This should work fine, but the thing is we have to use Plumbing Fixture families that have the Flow Configuration set to Preset and not to Fixture units.
So when I use this code on system that the plummbing fixtures flow config is set to Preset I get Invalid value
                //do something
                //do something
            else
                return dFlow;
So the FlowConversionMode only works with Fixture units.
The solution would be getting the FlowConversionMode to return Valves or Tanks values whether we use Preset or Fixture Units families.
