I want to create a dimension for a legend by Revit 2018 API. When I run the Add-in, It Worked,but the dimension is invisible and the dimension value is a negative number. If i create a new detailline, and use the reference of the detailline, the dimension is correct. But i don't want to create detailline. what can i do?
this is my code:
Transaction trans = new Transaction(m_Doc);
trans.SetName("create dimension");
trans.Start();
Reference reference = uIDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, "pick a legend");
ReferenceArray references = new ReferenceArray();
Element element = m_Doc.GetElement(reference);
List<Edge> edges = GetEdges(element); //get two Parallel edges
references.Append(edges.ElementAt(0).Reference);
references.Append(edges.ElementAt(1).Reference);
Line left_edge = edges.ElementAt(0).AsCurve() as Line;
Line right_edge = edges.ElementAt(1).AsCurve() as Line;
Line line = Line.CreateBound(left_edge.GetEndPoint(0), right_edge.GetEndPoint(1));
Dimension dim = m_Doc.Create.NewDimension(view, line, references);
trans.Commit();
private List<Edge> GetEdges(Element element)
List<Edge> edges = new List<Edge>();
Options options = new Options
ComputeReferences = true,
IncludeNonVisibleObjects = false
var geoEle = element.get_Geometry(options);
foreach (var item in geoEle)
GeometryInstance geometryInstance = item as GeometryInstance;
if (geometryInstance != null)
GeometryElement geometryElement = geometryInstance.GetInstanceGeometry();
foreach (GeometryObject geoObject in geometryElement)
if (geoObject is Solid)
Solid solid = geoObject as Solid;
if (!solid.Faces.IsEmpty)
foreach(Face face in solid.Faces)
PlanarFace p_face = face as PlanarFace;
if (p_face.FaceNormal.IsAlmostEqualTo(XYZ.BasisZ))
EdgeArray edgeArray = p_face.EdgeLoops.get_Item(0);
foreach (Edge edge in edgeArray)
Line line = edge.AsCurve() as Line;
if (line.Direction.IsAlmostEqualTo(XYZ.BasisY) || line.Direction.IsAlmostEqualTo(XYZ.BasisY.Negate()))
edges.Add(edge);
if (edges.Count > 0)
break;
return edges;
