Use Revit with BatchPrint: How can I hide logo and window at the launching?
pmeigneux
pmeigneux
I currently launch Revit with a BatchPrint.
I would like to know if there is a way to hide the Revit logo and his window which appears at the screen during the launching.
Thanks for your response,
Philippe
jeremytammik
Dear Philippe,
Thank you for your query.
I am not aware of any such possibility, and I am pretty sure that the Revit API does not provide any support for this either.
However, I am also pretty sure that you can easily achieve what you are after using the Windows or .NET API.
I would suggest searching the Internet for solution to suppress a flash screen.
You might be able to use some of the techniques described in my stand-alone app to detect and close an arbitrary Windows form:
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
I hope this helps.
Please let us know how you end up solving this, in case anyone else runs into the same requirement.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Dale.Bartlett
Not sure if this is at all helpful, but I use the following to hide a batch process command screen:
ProcessStartInfo startInfo = new ProcessStartInfo();
            startInfo.CreateNoWindow = true; // hide command window
            startInfo.WindowStyle = ProcessWindowStyle.Hidden;
            startInfo.FileName = lstrBatFileNameFull;
            startInfo.Arguments = args;
            System.Diagnostics.Process.Start(startInfo);
______________
Yes, I'm Satoshi.
callumf
To add to this solution, use this to suppress the splash screen:
startInfo.Arguments = '/nosplash'
On a side note, has anyone had any success using this line when opening Revit 2017? The exact same code opens 2016 silently, but 2017 seems to be ignored:
pmeigneux
Thank you very much.
Your startInfo.Arguments = '/ nosplash' solution works for Revit 2016 and is back in 2017.
Philippe.
callumf
Glad it worked Phillippe.
Im still interested to know if anyone has managed to open Revit 2017 silently, as you can Revit 2016 with this switch:
