Use NewCrossFitting() to connect four pipes which in different types,the new family instance of a cross fitting belong to which familySymbol?
1240904365
1240904365
jeremytammik
Implement the desire model manually through the user interface. When you are happy with it, use RevitLookup to analyse the result and find out:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
IbrahimNaeem
1- let the user select the pipe whose the desired cross family type is defined in its routing preferences prior to hitting the tool button.
2- extract the desired cross family type.
3- do the NewCrossFitting()
4- use FamilyInstance.ChangeTypeId(desiredFamilyType.Id) method to change the created cross to the desired cross family.
Hope this helps!
Hi,I mean i need to make sure the  pipe fittings to be generated is the type i want,when the  four pipes in different pipeType ,Instead of i don't know how to use LookUp to check what fittingType it generated.When i use NewCrossFitting,i find that what fittingType it generated seems to be uncontrolled,Maybe it has something to do with the order of parameters?
jeremytammik
I believe you can simply place the desired fittings first and then connect their connectors to automatically generate the types between them. Read the series of experiments to implement a rolling pipe offset:
http://thebuildingcoder.typepad.com/blog/2014/01/final-rolling-offset-using-pipecreate.html
Jeremy Tammik
The Building Coder
