Updating an existing .NET Framework project into a .NET Core one
Ramoon_Bandeira
Message 1 of 26
Ramoon_Bandeira
Now that Revit 2025 is out, Naturally, most developers will need to upgrade their existent .Net Framework Projects into .NET Core 8.0 project.
Is there a step by step guide to update an existing .NET Framework 4.8 project into a .NET core 8.0 ?
I`ve been attempting to use microsoft upgrade feature but all attempts of my part have failed miserably so far.
Thanks.
Replies (25)
Message 21 of 26
nice3point
This is a NuGet restore issue: https://github.com/dotnet/project-system/issues/3164
If you are using Nuke, please clean obj folder before compilation
https://github.com/jeremytammik/RevitLookup/blob/dev/build/Build.Clean.cs#L14
And if you're using a different batch build, write more details
Message 22 of 26
Extraneous
@nice3point I use the standard Visual studio's Batch build:
Alexander Zuev
In BIM we trust
Facebook | Linkedin | Telegram
Message 23 of 26
retug_austin
I am about to go through the upgrade process myself, thank you to everyone in this thread, the information is very valuable. Do people have a preference on one vs two cs.proj's solution as @kevinaugustino mentioned (pre 2025 and  2025 and beyond)?
@kevinaugustino , Do you like your setup? I would assume that you have to maintain two code basis now, if you make an update to one cs.proj you have to do the same for the other?
Message 24 of 26
eN27
A separate folder is mandatory, there is no backward compatibility, net 8.0 (revit 2025) dlls can not be used with net 4.8 (revit  2024).
Message 25 of 26
SwainStrain
Thank you. I resolved the issue by inserting these two property groups in the project file::
    <PropertyGroup Condition="'$(Configuration)' == '2024Debug'">
        <RevitVersion>2024</RevitVersion>
        <TargetFramework>net48</TargetFramework>
    </PropertyGroup>
    <PropertyGroup Condition="'$(Configuration)' == '2025Debug'">
        <RevitVersion>2025</RevitVersion>
        <TargetFramework>net8.0-windows</TargetFramework>
    </PropertyGroup>
Message 26 of 26
SerhanB
Batch build is broken so I use a batch file containing follows:
msbuild .\revitadd-in.sln -p:Configuration=R2025 -p:Platform=x64 -t:rebuild -restore -p:RestorePackagesConfig=true -v:m
msbuild .\revitadd-in.sln -p:Configuration=R2024 -p:Platform=x64 -t:rebuild -restore -p:RestorePackagesConfig=true -v:m
msbuild .\revitadd-in.sln -p:Configuration=Debug -p:Platform=x64 -t:rebuild -restore -p:RestorePackagesConfig=true -v:m
msbuild .\revitadd-in.sln -p:Configuration=Release -p:Platform=x64 -t:rebuild -restore -p:RestorePackagesConfig=true -v:m
Serhan BAKIR
http://www.stand.com.tr/
