Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Updating an existing .NET Framework project into a .NET Core one
Ramoon_Bandeira
Message 1 of 26
Ramoon_Bandeira
Now that Revit 2025 is out, Naturally, most developers will need to upgrade their existent .Net Framework Projects into .NET Core 8.0 project.
Is there a step by step guide to update an existing .NET Framework 4.8 project into a .NET core 8.0 ?
I`ve been attempting to use microsoft upgrade feature but all attempts of my part have failed miserably so far.
Thanks.
Replies (25)
Message 2 of 26
nice3point
You can try templates that support writing add-ins for the .Net Framework and .Net Core https://github.com/Nice3point/RevitTemplates
For existing projects the correct way is to migrate .csproj to DotNet SDK style, to avoid errors it is better to do it manually.
SDK style csproj sample: https://github.com/Nice3point/RevitTemplates/blob/develop/samples/SingleProjectApplication/RevitAddI...
Message 3 of 26
ricaun
If the microsoft upgrade fails you need to unload the project and update the csproj manually.
Most of the time is remove alot of things in the csproj to update to SDK style. If you need help just send me a message.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 4 of 26
j0hnp
I've just been starting a new visual studio file from the template that @nice3point linked above and bringing in all my code files. I've found that it has been easier for my code base(s) for my tools. I also get access to all the cool features built into those new templates.
john.pierson
expert elite / design technologist / dynamo package creator
designtechunraveled.com
Message 5 of 26
CLindballe
What about shared projects? How do I handle the migration to .net 8.0? I have problems with the assembly reference.
Update:
I fixed it and it now works for Revit 2025 with with SharedProject.
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
    <TargetFrameworks>net8.0-windows</TargetFrameworks>
<UseWPF>true</UseWPF>
    <RootNamespace>LindballeTools.Revit</RootNamespace>
    <ImplicitUsings>enable</ImplicitUsings>
    <Nullable>enable</Nullable>
    <Platforms>AnyCPU;x64</Platforms>
<CopyLocalLockFileAssemblies>true</CopyLocalLockFileAssemblies>
  </PropertyGroup>
<ItemGroup Condition="'$(TargetFramework)' == 'net8.0-windows'">
<PackageReference Include="Revit_All_Main_Versions_API_x64" Version="2025.0.0" />
</ItemGroup>
Message 7 of 26
ricaun
I tried to update an old version of RevitLookup to see.
Update old version of RevitLookup to Sdk Style.
Message 8 of 26
harrymattison
One thing I've found is that the old-style PostBuildEvent doesn't work in the new-style CSPROJ
This used to work
    <PostBuildEvent>"C:\Program Files (x86)\Windows Kits\10\bin\10.0.22000.0\x64\signtool.exe" sign /f "C:\Users\harry\Documents\Boost Your BIM\BoostYourBIM.pfx" /fd SHA256 /p $(CodeSignPassword) /v $(TargetPath)
mkdir "C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)"
copy /Y $(ProjectDir)$(TargetName).addin "C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\"
copy /Y $(TargetPath) "C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)"
copy /Y $(TargetDir)$(TargetName).pdb "C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)"
"C:\Program Files\Autodesk\Revit $(Configuration)\Revit.exe" "C:\Users\harry\Documents\rvt\2023.rvt"</PostBuildEvent>
When updating this project, delete that section from the CSPROJ and enter the code in here
The result will be this entry in the CSPROJ
  <Target Name="PostBuild" AfterTargets="PostBuildEvent">
    <Exec Command="&quot;C:\Program Files (x86)\Windows Kits\10\bin\10.0.22000.0\x64\signtool.exe&quot; sign /f &quot;C:\Users\harry\Documents\Boost Your BIM\BoostYourBIM.pfx&quot; /fd SHA256 /p $(CodeSignPassword) /v $(TargetPath)&#xD;&#xA;mkdir &quot;C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)&quot;&#xD;&#xA;copy /Y $(SolutionDir)$(TargetName).addin &quot;C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\&quot;&#xD;&#xA;copy /Y $(TargetPath) &quot;C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)&quot;&#xD;&#xA;copy /Y $(TargetDir)$(TargetName).pdb &quot;C:\ProgramData\Autodesk\Revit\Addins\$(Configuration)\$(TargetName)&quot;&#xD;&#xA;&#xD;&#xA;&quot;C:\Program Files\Autodesk\Revit $(Configuration)\Revit.exe&quot;" />
  </Target>
Message 9 of 26
nice3point
try to use this package https://github.com/Nice3point/Revit.Build.Tasks and add these lines if you just want to copy files:
<PropertyGroup>
    <PublishAddinFiles>true</PublishAddinFiles>
</PropertyGroup>
or copy target directly in your .csproj file:
https://github.com/Nice3point/Revit.Build.Tasks/blob/main/source/Nice3point.Revit.Build.Tasks/target...
I recommend to always use Target instead of PostBuildEvent
Message 10 of 26
harrymattison
If you are seeing a lot of these warnings
Warning CA1416 This call site is reachable on all platforms. 'FormPrintSuppression' is only supported on: 'windows'.
You can make it go away by adding
[SupportedOSPlatform("windows")]
before the definition of the class like
    class Ribbon : IExternalApplication
Message 11 of 26
nice3point
@harrymattison   dont use [SupportedOSPlatform("windows")], use TargetFramework net8.0-window instead of net8.0
Sample:
Message 12 of 26
harrymattison
I already am using net8.0-windows but I
still get the warnings
This suggested it could be due to GenerateAssemblyInfo = false, but I
changed that to true and still get the warnings
https://github.com/dotnet/roslyn-analyzers/issues/4983#issuecomment-852738069
Message 13 of 26
Ramoon_Bandeira
After starting a new .net 8.0 class library project. i had it all working perfectly, building the project from revit 19 to 25 seamlessly. Up till i decided to set the Assembly Neutral Language.
After that, i could still build to 2025 version, but versions prior to that all fail resulting on the following error:
Severity Code Description Project File Line Suppression State
Error MC1000 Unknown build error, 'Could not find type 'System.Resources.NeutralResourcesLanguageAttribute' in assembly 'C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.8\Facades\System.Runtime.dll'.' MyAssembly_Core C:\Program Files\dotnet\sdk\8.0.202\Sdks\Microsoft.NET.Sdk.WindowsDesktop\targets\Microsoft.WinFX.targets 211
Any guide?
I cant roll it back, even if i set it back to None. the solution wont rebuild for prior versions to 25
Message 14 of 26
kevinaugustino
I just upgraded one of my plugins and here are the bulk of the steps I followed:
1. Install the .NET upgrade assistant as a Visual Studio extension: https://learn.microsoft.com/en-us/dotnet/core/porting/upgrade-assistant-install#install-the-visual-s...
2. Open my .sln, right-click the sln in the solution explorer, choose 'Upgrade'
3. Follow the steps in the upgrade wizard ("Upgrade project to a newer .net version" --> "Side by side project upgrade" --> "New project" --> name it something like "{projectname}-netCore" or whatever)
4. Close the sln, then open the new .csproj it created in any text editor and make the following edits:
5. Remove this line: <GenerateAssemblyInfo>false</GenerateAssemblyInfo>
6. Added these 3 lines to the first PropertyGroup:
<AssemblyName>PUT_PROJECT_NAME_HERE</AssemblyName>
<RootNamespace>PUT_PROJECT_NAME_HERE</RootNamespace>
<NoWarn>CA1416;</NoWarn>
You probably don't need to do this but I wanted to keep my .dlls named the same for consistency with my pre-2025 plugins
7. If your project has a post-build command, you'll need to switch it over to the new format. It'll look something like this:
<Exec Command='
PUT COMMAND HERE
</Target>
Rather than:
<PropertyGroup>
<PostBuildEvent>PUT COMMAND HERE</PostBuildEvent>
</PropertyGroup>
Obviously this also applies to pre-build events. Don't ask me why the .net upgrade assistant didn't handle this for you.
8. If your build configurations have spaces in their names, switch them to underscores because apparently newer .nets have problems with spaces. EX: "Debug 2025" --> "Debug_2025"
9. Open the .sln
10. In the Solution Explorer, right-click the Properties folder for the new netCore project --> Add new item --> choose "Assembly Info File" and name it AssemblyInfo.cs. Then open that file and add this line to the bottom: [assembly: SupportedOSPlatform("windows")] . This way you won't get spammed with warnings about '...this call site is reachable on all platforms...'
Message 15 of 26
Ramoon_Bandeira
Well... i`ve done that, this time i didnt touch the code for the Assembly Neutral Language, however, i keep getting the same error:
Error MC1000 Unknown build error, 'Could not find type 'System.Resources.NeutralResourcesLanguageAttribute' in assembly 'C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework\.NETFramework\v4.8\Facades\System.Runtime.dll'.' MyProject_Core C:\Program Files\dotnet\sdk\8.0.202\Sdks\Microsoft.NET.Sdk.WindowsDesktop\targets\Microsoft.WinFX.targets 211
Message 16 of 26
kevinaugustino
I've never messed with any Assembly Neutral Language. I just have 2 separate projects in my solution, one for Revit 2021-2024 targeting .net framework 4.8.1, and the other for Revit 2025 targeting .net8.0-windows.
You're getting that error while trying to the build your .net8.0-windows project that is referencing the Revit 2025 .dlls? It's weird that the error refers to .net framework 4.8, since nothing in your project should be referencing .net framework after upgrading. Do you have any .net framework nuget packages being referenced from your .net8.0-windows project? Or maybe you accidentally referenced older Revit .dlls built against .net framework? In the Solution Explorer, do you have any warnings in the Dependencies?
Message 17 of 26
Ramoon_Bandeira
I`m trying to keep both my .Net Framework, and my .NET Core project into a single project of visual Studio.
The redirections could be made automatically based on the configuration i`m running.
I even managed to make it work for a little while. For a moment i could run the same project for both revit 2025 and its prior versions.
However, suddenly, this issue come to light, and nothing that i did solved it.
I`ve seen @ricaun incredible guide on updating the RevitLookup, i got a couple ideas from it.
I guess that the issue i have is due to having multiple resource files (i.e multiple resource files for localizing texts based on the language that the user is using on revit at the moment), on this case, the .NET Compiler may be getting crazy abouth wich language to choose as the default one, hence the error message.
Anyway, i`ll keep looking for solutions, and i`ll keep you informed about it.
Thanks.
Message 18 of 26
mhannonQ65N2
You can apply that attribute to your whole class library by doing:
Message 19 of 26
nice3point
You can apply that attribute to your whole class library by doing: [assembly: SupportedOSPlatform("windows")]
Please don't. Just use TargetFramework net8.0-window. Your problem is probably in something else, you can better send your .csproj
Message 20 of 26
Extraneous
Hi guys, please look at how I managed to change my project to a sdk-style: https://github.com/Tereami/ArchParametrisation/blob/master/ArchParametrisation/ArchParametrisation.c...
Everything works ok, but with one exception: Batch build didn't work now, catches an error
NETSDK1005 Assets file 'project.assets.json' doesn't have a target for 'net47'.
In the same time, every configuration separately builds ok! I've tried to delete .vs and obj folders, restart my computer, upgrade msbuild and nuget, doesn't help.
Alexander Zuev
In BIM we trust
Facebook | Linkedin | Telegram
