Update Element location based on parameter value
sensiblehira
sensiblehira
I have created X,Y,Z parameters for my family Instances and I want to update the location of my elements if values of my parameters are changed (without having to click anywhere else).
Is there a way to do this?
I am trying to trigger an event from OnStartUp, but since it is a custom parameter I can use GetChangeTypeParameter
GetChangeTypeAny is not responding to the changes in my case
I do not want to call the trigger for externalcommand
(the end user doesn't want to click anywhere else after modifying the parameter)
scgq425
Hi @sensiblehira :
is like a monitor document changed issue , if the element changed or modify-location , u can use the interface `DocumentChangedEventArgs`  to get document changed , and then monitor the target element which need to update location-paramaters.
 /// <summary>
        /// events about revit document changed
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        void AppChangedDocumented(object sender, Autodesk.Revit.DB.Events.DocumentChangedEventArgs e)
            var doc = e.GetDocument();
            try
                var addElems = e.GetAddedElementIds();
            catch (NullReferenceException)
            try
                var modifyElems = e.GetModifiedElementIds();
            catch (Exception)
            try
                var deletedElems = e.GetDeletedElementIds();
                foreach (var deletedElem in deletedElems)
                    var deleted = new DeletedJsonStruct()
                        ElementId = deletedElem.ToString(),
                        Locate = "(1,2,3),(3,4,5)",
                        MatchName = "Deleted"
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
sensiblehira
So here is how I solved my problem:
I was creating my Parameters from my code so
1- I firstly shifted the creation of my project parameters to the OnDocumentOpened Event
2- I returned the GUID of the parameter being created as the return type of my parameter creation method
3- using the Guid i got the parameter and its element id
4- Registered my updater in OnDocumentOpened Event (since I cannot create parameters in OnStartup I cannot register the updater without creating the parameter first)
