How to get parameters that have values as Combobox.
qoreodlf37
qoreodlf37
Hi, I'm trying to get parameters that have values as combobox.
I know that parameter has combobox when parameter's Storage Type is ElementId.
But some of Integer parameters has combobox.
And I find out that GetDataType() of Integer parameters having combobox have 'Empty TypeId'.
Is it right that all Integer parameters having combobox have 'Empty TypeId' when GetTypeId()?
Thank you!
Mohamed_Arshad
Hi @qoreodlf37
    This question has been discussed in Revit API forum, Revit API don't have support for this. Kindly check the below link for additional references.
Reference Links
https://stackoverflow.com/questions/40789198/revit-api-how-to-retrieve-possible-values-for-parameter...
https://forums.autodesk.com/t5/revit-api-forum/retrieve-list-of-possible-values-for-a-parameter/td-p...
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
qoreodlf37
Sad news.. but Thank you!!😂
