Update category of copied schedule/quantity
Hey,
I am using the following code to copy a schedules/quantities element from on document to another.
private static ICollection<ElementId> DuplicateSchedules(Document from, IEnumerable<ViewSchedule> schedules, Document to)
    var ids = schedules.AsEnumerable<View>().ToList<View>().ConvertAll<ElementId>(v => v.Id);
    return DuplicateElementsAccrossDocuments(from, ids, to);
private static ICollection<ElementId> DuplicateElementsAccrossDocuments(Document from, ICollection<ElementId> ids, Document to)
    ICollection<ElementId> copies = null;
    using (var transaction = new Transaction(to, "Duplicate Elements"))
        if (transaction.Start() == TransactionStatus.Started)
            // Use destination types if duplicates found
            var options = new CopyPasteOptions();
            options.SetDuplicateTypeNamesHandler(new HideAndAcceptDuplicateTypeNamesHandler());
            copies = ElementTransformUtils.CopyElements(from, ids, to, Transform.Identity, options);
            // Delete cannot copy duplicates warning
            var failureOptions = transaction.GetFailureHandlingOptions();
            failureOptions.SetFailuresPreprocessor(new HidePasteDuplicationTypesPreprocessor());
            transaction.Commit();
    return copies;
It works, but the copied schedule is placed under a ??? category.
The category can be changed manually by editing Projectbrowser -> Constraints.
Sadly I wasn't able to find a way to do this in the API. Is that even possible?
bump
PavelAnd
Hello @Anonymous. Is this a text parameter? How about creating a new transaction after adding specifications and filling out their parameter with the code below?
foreach (ElementId copy in copies)
    doc.GetElement(copy).LookupParameter("Projektbrowser Gliederung 1").Set("ALLGEMEIN");
Best regards, Pavel Plotitsyn.
This works, thanks. Do you know if it's possible to create a new node like "ALLGEMEIN"?
PavelAnd
You can write any name, which you want and it will add node to your project browser.
