Could not create Revit ribbon button panel in AddIns
chau.nguyen92
chau.nguyen92
I am trying to create Revit plugin. However, I could not create a new ribbon panel in "Add Ins" tab on Revit. I have implemented the methods needed in App class. I'm not sure what is missing here. I attach the link here to the repo. I also attach image of my current situation and my goal, and a snap shop of my App class for quick look
My git link:
https://gitlab.com/chau1510/MyFirstRevitPlugin
Thank you very much
jeremytammik
Welcome to Revit API programming!
Simply work through the getting started material and tutorials and all will be clear:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That is probably more efficient than trying to figure it out for yourself.
Good luck and have fun!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
chau.nguyen92
I followed the tutorial but it did not work for me
chau.nguyen92
Thank you very much.
I realized I did not edit the AddIn file properly. Must point to the right class in FullClassName. I did not edit from Command class to App class
