Units of Global parameter value
Hi!
I'm trying to modify global parameters through Revit API (with Python scripts in Dynamo to be more exact). The API calls all work alright, but for some reason the GlobalParameter.GetValue().Value seems to return values in inches regardless of the units set in the doument. The document units are in mm and the the Global Parameters dialog in Revit also reports the parameters in mm. If I get the value from the parameter it returns it in inches (divided by 304.8) and when I set the value it also interprets it as inches.
Why is that? Is it a bug or a feature?
Taavi
jeremytammik
Dear Taavi,
That is absolutely the expected behaviour.
The internal Revit database length unit is and always will be feet. That cannot be changed:
http://thebuildingcoder.typepad.com/blog/2011/03/internal-imperial-units.html
What you see in the user interface is just a view, and you can control what you would like to see in your view.
Similarly, your add-in or Python script has to retrieve the internal database values in feet and convert them to the desired view.
I hope this clarifies.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
That explains things.
Thanks!
For further reference, since I couldn't find any good explanations how to convert the internal value to project units and vice versa, I found this way through the Revit API:
gp_type = GlobalParameter.GetDefinition().UnitType
display_units = doc.GetUnits().GetFormatOptions(gp_type).DisplayUnits
gp_type returns the UnitType of this global parameter (lenght, area, volume etc.)
display_units returns the DisplayUnitType to which Revit converts the internal value for displaying in the user interface.
Then I could use the UnitUtils class to convert between internal and project value (display_unit), irrespective of which unit the user has set in the project units dialog and which UnitType the global parameter has.
Totally unrelated but can anybody help me in reducing the digits of the fraction for my pipe sloping 0'-1 256/256" is a little difficult to use setting sleeves and hitting center lines when rotating the fittings and dropping from a horizontal branch into the building drain.
Please and Thank you.
Gus
