unique ID for project
phildebrandt
phildebrandt
Does anyone know if there is a unique ID number for projects stored in the Revit file?
I found one in the ProjectInfo.uid (see code snippit below)
            Autodesk.Revit.DB.Document actdoc = this.ActiveUIDocument.Document;
ProjectInfo pi = actdoc.ProjectInformation;
pid = pi.UniqueId;
However, this is the UID of the ProjectInfo object, it can be the same in 2 different Revit files.
I'm trying to find a UID that is the same for the local and central files of the same project but different between seperate projects.
Anyone know if one exists?
This is almost the same question discussed here -> http://forums.autodesk.com/t5/Autodesk-Revit-API/How-do-you-access-a-model-s-GUID-or-UniqueId-using-...
I know this is an old post but I was facing the same issue and I found something that may help you. This works for Revit 2013.
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
string ifcproject = ExporterIFCUtils.CreateProjectLevelGUID(doc, Autodesk.Revit.DB.IFC.IFCProjectLevelGUIDType.Project);
This is the website were I found the info
http://matteocominetti.com/revit-api-2013-ifcproject-guid-in-c/
http://matteocominetti.com/revit-api-2013-get-uniqueid-from-ifcguid-and-from-guid/
Marc
hi,
Did you find  solution for your problem, I'm facing the same issue right now
jeremytammik
I once created a dedicated add-in to address this issue:
http://thebuildingcoder.typepad.com/blog/2016/04/named-guid-storage-for-project-identification.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you Jeremy, I have implemented that, and  I will let you know about the result :).
mizrachi_amir
Fast forward 7 years, anything new with that?
jeremy_tammik
Nope, sorry, no news on this front. You might want to have a look and see whether there is a wish list item for this functionality in the Revit Idea Station and vote for that...
