undo sample
undo sample
sonicer
undo sample
sonicer
Is there a sample c# how undo some transaction by name?
matthew_taylor
Hi @sonicer,
Transactions can only be undone in order.
The only way to undo the last transaction is use the 'undo' command, or issue it via postcommand.
You may of course rollback your own transactions.
You would do well to explain what it is you're trying to achieve.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
sonicer
I would like create tags....with button that is in a form ...but if user click Cancel button need undo last transaction - tag created
matthew_taylor
You should just be able to return 'Result.Cancelled'.
If that doesn't do what you want, you're going to have to show code to explain more fully.
Cheers,
-Matt
