Create Scope Boxes
Create Scope Boxes
Create Scope Boxes
I saw on this forum that at least in 2012, scope boxes could not be created or resized via the API. Is this still the case?
My goal is to select multiple walls, create an elevation view parallel to the walls, then associate a scope box with the view that is parallel to the wall, and the size of the wall.
I beleive these two links are similar, but not the same as what I am going for:
http://thebuildingcoder.typepad.com/blog/2012/08/set-view-section-box-to-match-scope-box.htmlhttp://thebuildingcoder.typepad.com/blog/2012/06/create-section-view-parallel-to-wall.html
Any help is greatly appreciated!
- Jed
Troy_Gates
They still aren't available in 2018 API.
I'd suggest adding it to the Revit Ideas forum as a wish list item and then post a link to it here for others to upvote it.
Daniel.Gijsbers
YES PLEASE, we need to be able to create scope box through the API so we can create them automatically from dynamo!!!
smbrennan
Stupid question from a non-programmer:
If the API doesn't support creation or manipulation of scope boxes, then how was this app developed?
https://apps.autodesk.com/RVT/en/Detail/Index?id=6897465823377340538&appLang=en&os=Win64
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Troy_Gates
That addin uses existing scopeboxes and copies them to create new ones.
