unable to set value for parameter in DirectShape
Hi;
I am trying to set value for one parameter which binding with Generic category( DirectShape) . and generate (PROCESS:1-BIN .
But setting value returned false.
my code:
using(TransactionGroup transGroup = new TransactionGroup(doc))
using(Transaction trans = new Transaction(doc))
transGroup.Start("Action");
trans.Start("SharedParam");
ProjectConstant con = new ProjectConstant(0,1,2,3,4,5,6,7,8,9,10,11);
var one = new One();
List<List<Curve>> Lines = one.Getlines(doc,linestylesA,linestylesB,option);
List<Curve> curvesParent = Lines.ElementAt(0) as List<Curve>;
List<Curve> curveMain = Lines.ElementAt(1) as List<Curve>;
SketchPlane sketchPlane = one.GetPlane(doc,curveMain,iResult);
one.ListPointDicUnfinished(curveMain,curveMain,doc,sketchPlane,linestylesB,pointsPropertiesALL,curveremoving,iResult);
one.ListPointDicUnfinished(curvesParent,curveMain,doc,sketchPlane,linestylesB,pointsPropertiesALL,curveremoving,iResult);
foreach(Curve B in curveremoving)
doc.Delete(B.Reference.ElementId);
List<IDictionary<int,object>> ONEpointsALLines = one.ListPointDictionary(pointsPropertiesALL);
///STEP 1 : CREATING SOLID GEOMETRY AND BINDING THE SHARED PARAMETER WITH GENERIC CATEGORY IF IT DOESNT HAVE IT ALREADY.
List<Solid> solids = one.GetSolids(ONEpointsALLines).ElementAt(0).ConvertAll(x => x as Solid);
var createshareParam = new Share();
Definition tt = createshareParam.Main(doc,_filename,_groupname,_defname,_deftype,targets);
///STEP 2 : CREATE DIRECT SHAPE
if(trans.Commit() != TransactionStatus.Committed)
return Result.Failed;
trans.Start("DirectShape");
List<ElementId> ListElementId = new List<ElementId> { };
for(int i = 0; i < solids.Count; i++)
List<GeometryObject> geo = new List<GeometryObject> { solids.ElementAt(i) as GeometryObject };
DirectShape ds = DirectShape.CreateElement(doc,new ElementId(BuiltInCategory.OST_GenericModel));
ds.GetOptions().ReferencingOption = DirectShapeReferencingOption.Referenceable;
ds.ApplicationId = "aplication id";
ds.ApplicationDataId = "geometry object id";
ds.SetShape(geo);
ds.SetName("MyShape" + i.ToString());
bool ll = ds.get_Parameter(tt).SetValueString(linestylesB);
ElementId IdDirectShape = ds.Id;
ListElementId.Add(IdDirectShape);
doc.Regenerate();
///STEP 3 : SETTING VALUE FOR PARAMETER IN DIRECT SHAPE
trans.Start("values");
foreach(ElementId elmentId in ListElementId)
Element directshape = doc.GetElement(elmentId);
bool rr = directshape.get_Parameter(tt as Definition).SetValueString(linestylesB);
transGroup.Assimilate();
return Result.Succeeded;
RPTHOMAS108
Don't use .SetValueString
"This method only applies to parameters of value types."
For the parameter in question lookup the storage type and use either:
Parameter.Set(ElementID), Parameter.Set(Double), Parameter.Set(Integer), Parameter.Set(String)
Thanks! it worked.
