Unable to save (Need immediate help)
I'm currently using the student version of Revit. Whenever I try to save a project, I get an error message saying "Failed to open document" and then a "Failed to save". I've uninstalled Revit from my computer 7 times already and did a hard reset on my computer multiple times as well. Please help. My homework is due February 5th, 2019.
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Good luck getting your homework completed and submitted in a timely manner!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
