Unable to rotate grids (three-point rotation)
Dear all,
I have created an application macro that rotates the model file using three-point rotation.
All element categories rotate except for grids.
Any help would be very much appreciated.
MACRO:
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace DDA_CSharpModule6
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("2B2E4EAB-59F7-492A-A125-BA0981A77D99")]
public partial class ThisApplication
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void RotateModelWithThreePoints()
UIDocument uidoc = this.ActiveUIDocument;
Document doc = uidoc.Document;
try
// Prompt user to select the center of rotation
XYZ centerPoint = uidoc.Selection.PickPoint("Select the center of rotation");
// Prompt user to select the end point to define the direction
XYZ endPoint = uidoc.Selection.PickPoint("Select the end point to define the initial direction");
endPoint = new XYZ(endPoint.X, endPoint.Y, centerPoint.Z); // Ensure end point is on the horizontal plane
// Prompt user for the final point
XYZ finalPoint = uidoc.Selection.PickPoint("Select the final point to define the angle of rotation");
finalPoint = new XYZ(finalPoint.X, finalPoint.Y, centerPoint.Z); // Ensure final point is on the horizontal plane
// Calculate the angle between the end point and final point around the center point
double rotationAngle = CalculateRotationAngle(centerPoint, endPoint, finalPoint);
// Define the rotation axis (Z-axis through centerPoint)
Line rotationAxis = Line.CreateBound(centerPoint, centerPoint + XYZ.BasisZ);
// Collect specified elements, including new categories
FilteredElementCollector collector = new FilteredElementCollector(doc)
.WhereElementIsNotElementType()
.OfCategory(BuiltInCategory.OST_Grids) // Grids
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Levels))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_SpecialityEquipment))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_GenericModel))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Tags))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Roofs))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_CurtainWallPanels))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_CurtainWallMullions))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_CurtainGrids))
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_VolumeOfInterest)) // Scope Boxes
.UnionWith(new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RoomSeparationLines)) // Room Separation Lines
.UnionWith(new FilteredElementCollector(doc).OfClass(typeof(ReferencePlane))); // Reference Planes
IList<ElementId> elementIds = collector.ToElementIds() as IList<ElementId>;
// Start a transaction to unpin elements and rotate the model
using (Transaction transaction = new Transaction(doc, "Rotate Model with Three Points on Horizontal Plane"))
transaction.Start();
// Unpin all pinned elements
foreach (ElementId id in elementIds)
Element element = doc.GetElement(id);
if (element != null && element.Pinned)
element.Pinned = false;
// Rotate all collected elements around the internal origin
ElementTransformUtils.RotateElements(doc, elementIds, rotationAxis, rotationAngle);
transaction.Commit();
TaskDialog.Show("Success", "The model has been successfully rotated using the specified three points on the horizontal plane.");
catch (OperationCanceledException)
TaskDialog.Show("Info", "Operation cancelled by user.");
catch (Exception e)
TaskDialog.Show("Error", string.Format("An error occurred while rotating the model: {0}", e.Message));
private double CalculateRotationAngle(XYZ center, XYZ start, XYZ end)
XYZ vector1 = new XYZ(start.X - center.X, start.Y - center.Y, 0);
XYZ vector2 = new XYZ(end.X - center.X, end.Y - center.Y, 0);
double dotProduct = vector1.X * vector2.X + vector1.Y * vector2.Y;
double magnitude1 = Math.Sqrt(vector1.X * vector1.X + vector1.Y * vector1.Y);
double magnitude2 = Math.Sqrt(vector2.X * vector2.X + vector2.Y * vector2.Y);
double cosTheta = dotProduct / (magnitude1 * magnitude2);
double angle = Math.Acos(cosTheta);
// Determine the direction of rotation using cross product (Z component)
double crossZ = vector1.X * vector2.Y - vector1.Y * vector2.X;
if (crossZ < 0)
angle = -angle;
return angle;
