Assign Shared Parameters to Family (CSharp Macro)
dwightduronidavy
Message 1 of 15
dwightduronidavy
Dear all,
I have written (prompted) an application macro to retrieve shared parameters (from shared parameters file) and assign to a specific family. However, I keep getting similar error messages [see attached]. Any help would be very much appreciated.
MACRO
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI.Selection;
using System.IO;
using System.Collections.Generic;
using System.Linq;
namespace DDA_CSharpModule8
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("4BE8D9CF-2B20-4F03-A56B-6B9C6AA11B06")]
public partial class ThisApplication
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void AssignSharedParametersMarkers()
UIApplication uiapp = new UIApplication(this.Application);
UIDocument uidoc = uiapp.ActiveUIDocument;
Document doc = uidoc.Document;
string sharedParameterFilePath = "C:\\Users\\dda\\OneDrive - XXXXX\\Documents\\01. Revit Families\\XXXX_Shared_Parameters_1.1.txt";
string familyName = "TestIVCoordCube";
string parameterGroupName = "Parametrics";
string[] parameters = { "CoordIssue_Eastings", "CoordIssue_Northings", "CoordIssue_Elev" };
try
// Check if shared parameter file exists
if (!File.Exists(sharedParameterFilePath))
TaskDialog.Show("Error", string.Format("Shared parameter file not found at: {0}", sharedParameterFilePath));
return;
// Set the shared parameter file in Revit
Autodesk.Revit.ApplicationServices.Application app = doc.Application;
app.SharedParametersFilename = sharedParameterFilePath;
// Open the shared parameter file
DefinitionFile sharedParameterFile = app.OpenSharedParameterFile();
if (sharedParameterFile == null)
TaskDialog.Show("Error", "Unable to open the shared parameter file.");
return;
using (Transaction transaction = new Transaction(doc, "Assign Shared Parameters to Family"))
transaction.Start();
// Find the required family in the project
FilteredElementCollector familyInstances = new FilteredElementCollector(doc)
.OfCategory(BuiltInCategory.OST_SpecialityEquipment)
.WhereElementIsNotElementType();
foreach (Element element in familyInstances)
FamilyInstance familyInstance = element as FamilyInstance;
if (familyInstance != null && familyInstance.Name.Equals(familyName, StringComparison.OrdinalIgnoreCase))
Family family = familyInstance.Symbol.Family;
// Open the family document for editing
Document familyDoc = doc.EditFamily(family);
foreach (string parameterName in parameters)
// Check if the parameter already exists
bool parameterExists = familyDoc.FamilyManager.Parameters
.Cast<FamilyParameter>()
.Any(param => param.Definition.Name == parameterName);
if (!parameterExists)
// Get the shared parameter definition
DefinitionGroup group = sharedParameterFile.Groups.get_Item(parameterGroupName);
if (group == null)
TaskDialog.Show("Error", string.Format("Parameter group not found: {0}", parameterGroupName));
return;
Definition definition = group.Definitions.get_Item(parameterName);
if (definition is ExternalDefinition externalDefinition)
// Create a new shared parameter
familyDoc.FamilyManager.AddParameter(
externalDefinition,
GroupTypeId.Data,
true
else
TaskDialog.Show("Error", string.Format("Invalid definition for parameter: {0}", parameterName));
return;
// Save and reload the family into the project
familyDoc.Save();
familyDoc.Close();
transaction.Commit();
TaskDialog.Show("Success", string.Format("Shared parameters assigned successfully to family: {0}", familyName));
catch (Exception ex)
TaskDialog.Show("Error", string.Format("An error occurred: {0}", ex.Message));
Replies (14)
Message 2 of 15
scgq425
Hi @dwightduronidavy :
this application type is error , you can change to this :
and the file need to imprt this reference and write `using System.IO`:
the last , in marco likely cant use the lasted c# version , you can change the quick code to some older write style :
	ExternalDefinition externalDefinition = definition  as ExternalDefinition;
	if (externalDefinition ==  null)
			externalDefinition,
			GroupTypeId.Data,
			true
	else
			return;
this is all code , you can run in you revit , and debug again , holp to help you .
 * Created by SharpDevelop.
 * User: Administrator
 * Date: 2024/12/5
 * Time: 9:15
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.IO;
using System.Linq;
namespace A
    [Autodesk.Revit.DB.Macros.AddInId("DC4F5661-F13E-487C-952B-F7A3DB8394CC")]
	public partial class ThisDocument
		#endregion
var uiapp = Application;
string sharedParameterFilePath = "D:\\ShareSample.txt";
try
return;
return;
if (group == null)
return;
			externalDefinition,
			GroupTypeId.Data,
			true
	else
			return;
familyDoc.Save();
familyDoc.Close();
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 3 of 15
dwightduronidavy
Hi scgq425,
Thanks for you help. However, I seems to be getting lots of errors (see below).
Message 4 of 15
scgq425
you can just modify the function , is likely my create a new project different with you project name and if also have problem ,  push you all code  :
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 5 of 15
dwightduronidavy
Modified function still generate the same errors
Message 6 of 15
scgq425
 you can push you all code about this marco
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 7 of 15
dwightduronidavy
Herewith code:
using System;
using System.Linq;
        #endregion
        public void AssignSharedParameters()
string sharedParameterFilePath = "C:\\Shared_Parameters_1.1.txt";
string[] parameters = { "CoordIssue_Eastings""CoordIssue_Northings""CoordIssue_Elev" };
try
TaskDialog.Show("Error"string.Format("Shared parameter file not found at: {0}", sharedParameterFilePath));
return;
TaskDialog.Show("Error""Unable to open the shared parameter file.");
return;
if (group == null)
TaskDialog.Show("Error"string.Format("Parameter group not found: {0}", parameterGroupName));
return;
            externalDefinition,
            GroupTypeId.Data,
            true
    else
            TaskDialog.Show("Error"string.Format("Invalid definition for parameter: {0}", parameterName));
            return;
familyDoc.Save();
familyDoc.Close();
TaskDialog.Show("Success"string.Format("Shared parameters assigned successfully to family: {0}", familyName));
TaskDialog.Show("Error"string.Format("An error occurred: {0}", ex.Message));
Message 8 of 15
scgq425
i paste this code to my revit ,is ok .
you shoule import the `Systems.IO` and using ` using System.IO;`
and  the import step is for this issue
1.
2.
using System;
using System.IO;
using System.Linq;
        	AssignSharedParameters();
        #endregion
try
return;
return;
if (group == null)
return;
            externalDefinition,
            GroupTypeId.Data,
            true
    else
            return;
familyDoc.Save();
familyDoc.Close();
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 9 of 15
dwightduronidavy
Hi scgq425,
After undertaking the above, the macro generated the attached errors
Message 10 of 15
dwightduronidavy
Herewith new version:
using System;
using System.IO;
using System.Linq;
using Autodesk.Revit.ApplicationServices;
namespace DDA_CSharpModule12
    [Autodesk.Revit.DB.Macros.AddInId("825BFCE5-C65B-410A-A72E-0A280B2F2280")]
            // Initialize UIApplication
            UIApplication uiapp = new UIApplication(this.Application); // Corrected to use `uiapp.Application`
            try
                    TaskDialog.Show("Error", String.Format("Shared parameter file not found at: {0}", sharedParameterFilePath));
                    return;
                Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
                    return;
                                    if (group == null)
                                        TaskDialog.Show("Error", String.Format("Parameter group not found: {0}", parameterGroupName));
                                        return;
                                    if (externalDefinition != null)
                                        // Add the shared parameter to the family
                                        familyDoc.FamilyManager.AddParameter(externalDefinition, GroupTypeId.Data, true);
                                    else
                                        TaskDialog.Show("Error", String.Format("Invalid definition for parameter: {0}", parameterName));
                                        return;
                            familyDoc.Save();
                            familyDoc.Close();
                    TaskDialog.Show("Success", String.Format("Shared parameters assigned successfully to family: {0}", familyName));
                TaskDialog.Show("Error", String.Format("An error occurred: {0}", ex.Message));
Error:
'DDA_CSharpModule12.ThisApplication' does not contain a definition for 'InternalStartup' and no extension method 'InternalStartup' accepting a first argument of type 'DDA_CSharpModule12.ThisApplication' could be found (are you missing a using directive or an assembly reference?) (CS1061) - C:\ProgramData\Autodesk\Revit\Macros\2024\Revit\AppHookup\DDA_CSharpModule12\Source\DDA_CSharpModule12\ThisApplication.Designer.cs:29,18
Message 11 of 15
scgq425
this error is the project name not same with my push name .  and in you push code , you deleted the most import function like this and i give you the step how to success use it and my project with marco :
			TaskDialog.Show("Error", "A");
		#endregion
this code is necessary for revit marco , so if you want to get a current marco you need to create for this step :
1.
create a marco :
2. import the refernce and paste this code to the current locate , rember the other code dont delte  .
            UIApplication uiapp = Application; // Corrected to use `uiapp.Application`
            try
                    return;
                    return;
                                    if (group == null)
                                        return;
                                    else
                                        return;
                            familyDoc.Save();
                            familyDoc.Close();
3.  add the using about  using System.IO; , and use the   AssignSharedParameters() in Module_Startup and then build this project  , this code will run in revit
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 12 of 15
dwightduronidavy
Hi  scgq425
The below code no long throw previous errors, however, now throws the attached error after execution
which prevents shared parameters being added to the Project Parameters and assigned to the family.
MACRO:
using System;
using System.Linq;
using System.IO;
namespace DDA_CSharpModule13
    [Autodesk.Revit.DB.Macros.AddInId("C544A221-18AB-4900-B1A5-C9C52D9FFDDE")]
            // Add any startup logic here, if needed.
            // Add any cleanup logic here, if needed.
        #endregion
            try
                    return;
                    return;
                // Collect family instances in the project
                FilteredElementCollector collector = new FilteredElementCollector(doc)
                foreach (Element element in collector)
                    if (familyInstance != null)
                        // Open family document outside the transaction
                        using (Transaction familyTransaction = new Transaction(familyDoc, "Assign Shared Parameters"))
                            familyTransaction.Start();
                                if (!familyDoc.FamilyManager.Parameters
                                    .Any(p => p.Definition.Name == parameterName))
                                    if (group == null)
                                        familyTransaction.RollBack();
                                        return;
                                    else
                                        return;
                            familyTransaction.Commit();
                        // Save and close the family document
                        familyDoc.Save();
                        familyDoc.Close();
                TaskDialog.Show("Success""Shared parameters assigned successfully.");
Message 13 of 15
scgq425
this error is you family file is read-only , you can check this like the picture , if is read-only you can cancel this bool or use anthor api is SaveAs();
also in you code , if loop every instance will " push the file is already exits exception" , beacuse you add paramater to all instance , but in logic you should add paramater in the ftamily document and re-load this . so you can change the file read-only and try again.
///familyDoc.SaveAs("E:\\A\\" + family.Name + ".rfa");
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 14 of 15
dwightduronidavy
Hi @scgq425
Thank you for the advice. Will take a look over the weekend and let you know how I get on.
Dwight
Message 15 of 15
dwightduronidavy
Dear all,
Herewith updated Macro which successfully retrieves parameters from a shared parameters file; adds to Project Parameters and then assign to family:
using System;
using System.IO;
using System.Linq;
        #endregion
        public void AssignSharedParametersAsProjectParameters()
            try
                    return;
                    return;
                if (group == null)
                    return;
                // Create a CategorySet for the categories you want the parameter to apply to.
                CategorySet categorySet = app.Create.NewCategorySet();
                categorySet.Insert(doc.Settings.Categories.get_Item(BuiltInCategory.OST_SpecialityEquipment));
                using (Transaction t = new Transaction(doc, "Add Project Parameters"))
                    t.Start();
                        if (definition == null)
                            TaskDialog.Show("Error", String.Format("Parameter not found in shared file: {0}", parameterName));
                            continue;
                        // Create an instance binding
                        InstanceBinding binding = app.Create.NewInstanceBinding(categorySet);
                        // Insert the parameter into the project using GroupTypeId instead of BuiltInParameterGroup
                        bool inserted = doc.ParameterBindings.Insert(definition, binding, GroupTypeId.Data);
                        if (!inserted)
                            TaskDialog.Show("Warning", String.Format("Parameter '{0}' may already exist or could not be inserted.", parameterName));
                    t.Commit();
                TaskDialog.Show("Success""Project parameters added successfully.");
@scgq425 thank you for you valuable help as usual
