Hi everyone,
Quick question I have some code that collects all rooms but i want to remove all "Not Placed" and Area over 0 via the following "private void"
I have written the following code but it throws a transaction issue:
/// <summary> /// Remove rooms not placed on the drawing /// or have a total area equal or less than zero /// </summary>
private void RemoveNotPlacedAndZeroAreaRooms(List<Room> rooms)
foreach (Room room in rooms)
if(room.Area <= 0 || room.Location == null)
rooms.Remove(room);
Is this code correct? Or am I missing something elsewhere in the code?
Could you please help
Simon Palmer
Solved by BobbyC.Jones. Go to Solution.
you must not modify a list while iterating over it.
Put the valid rooms into another list.
Revitalizer
Exactly. I have fallen into that trap many times. Sample pseudo-code:
private void RemoveNotPlacedAndZeroAreaRooms(List<Room> rooms) { foreach (Room room in rooms) { // collect room ids to delete if(room.Area <= 0 || room.Location == null) { idsToDelete.Add(room.Id); } } // now delete doc.Delete(idsToDelete); }
I like to use ienumerable extensions to clarify and simplify these filtering tasks.
public static IEnumerable<Room> WhereIsPlacedAndEnclosed(this IEnumerable<Room> rooms)
//IsPlaced() and IsEnclosed() Room extensions would make this even better
var placedRooms = rooms.Where(r => r.Area >= 0).Where(r => r.Location != null);
return placedRooms;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { var activeDoc = commandData.Application.ActiveUIDocument.Document; var roomCollector = new FilteredElementCollector(activeDoc); var placedRooms = roomCollector. OfClass(typeof(SpatialElement)). OfType<Room>(). WhereIsPlacedAndEnclosed(); foreach (var room in placedRooms) { //do your thing. } return Result.Succeeded; }
This is a little off topic, but this code had a slight smell I thought I could ignore, but I was wrong 🙂
A Room that is not placed is by default also not enclosed. So unless you must specifically differentiate between not placed and placed but not enclosed rooms, a single test for enclosed rooms should suffice for filtering. That simplifies things down to an extension method for determining if a room IsEnclosed(). Then you could use it with the standard linq Where() method, and ditch the WhereIsPlacedAndEnclosed() method.
var enclosedRooms = roomCollector. OfClass(typeof(SpatialElement)). OfType<Room>(). Where(r => r.IsEnclosed());
As for the implementation of the IsEnclosed() method, testing that the room.Area > 0 is *probably* OK, but testing this inequality without a tolerance is another code smell you may want to account for in your production code.
public static bool IsEnclosed(this Room room) { var isEnclosed = room.Area > 0; return isEnclosed; }
And just as I finish typing this and clearing my mind of niggling smells, my last PR has been approved and merged and I can get back to work. If the rest of the day goes half as well then I'll consider this an early Good Friday 🙂
