Unable to obtain the GeometryObject of a beam
I want to obtain the GeometryObject to acquire the outline of a series of beams. After the FamilyInstanceFilter, there are few elements pass the filter, I think its the problem of instruct get_Geometry(opt). How to fix that problem which was not appear when I did the same to columns?
Another question is will the overlap parts of the beams' outline be removed automatically?
See the codes:
FamilySymbol beam = doc.GetElement(new ElementId(153240)) as FamilySymbol;
FamilyInstanceFilter familyInstanceFilter = new FamilyInstanceFilter(doc, beam.Id);
FilteredElementCollector filteredElements = new FilteredElementCollector(doc);
filteredElements = filteredElements.WherePasses(familyInstanceFilter);
foreach (FamilyInstance element in filteredElements)
if (element != null)
TaskDialog.Show("Found", "sa");
Options opt = application.Create.NewGeometryOptions();
opt.ComputeReferences = true;
opt.DetailLevel = ViewDetailLevel.Medium;
//opt.View = doc.ActiveView;
GeometryElement e = element.get_Geometry(opt);
foreach (GeometryObject geoObj in e)
//doc.Regenerate();
//TaskDialog.Show("Found", "sa");
GeometryInstance geoInstance = geoObj as GeometryInstance;
GeometryElement geoElement = geoInstance.GetInstanceGeometry();
Transform insTransform = geoInstance.Transform;
foreach (GeometryObject geoObj2 in geoElement)
Solid solid2 = geoObj2 as Solid;
if (solid2.Faces.Size > 0)
foreach (Edge edge in solid2.Edges)
Curve curve = edge.AsCurve();
TaskDialog.Show("revit", edge.AsCurve().GetType().ToString());
jeremytammik
First of all:
Have you installed RevitLookup?
https://github.com/jeremytammik/RevitLookup
This invaluable tool enables you to explore the Revit database interactively via the API, including the possibility to snoop through the geometry hierarchy.
Secondly:
You can always use the SDK sample ElementViewer to see how to access element geometry via the API.
If you debug through that twice, selecting once a beam and once a column, you will see what different traversal paths are used to parse the geometry hierarchy.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks for answering
It was the wrong method I have used, I forgot to transform the GeometryElement.
But that answer does help
Best wishes
