Addin not Showing
Addin not Showing
Message 1 of 11
Addin not Showing
i deployed my addin in revit 2016 Addin folder but when i open revit.exe , its not showing or not working. can someone help me.
Replies (10)
Message 2 of 11
jeremytammik
Please work through the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
It explains all you need to know.
If you are in a hurry and want to skip everything else, you can just check out the hello world samples in the developer guide:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-BEEA9781-C8A5-4324-B213-B6A44BA78051
Good luck!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
Actually its working previously but now its not loading and other addin get loaded..
Message 4 of 11
stever66
do both addins have the same guid number in the manifest file?
Message 5 of 11
Thanks... i got solution
Message 6 of 11
denise.lollar
What is the solution?
Message 7 of 11
jeremytammik
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 11
jeremytammik
It is basically very simple and needs no coding experience or prowess.
There are just two files:
  • .NET Assembly *.DLL
  • Add-in manifest *.ADDIN
Both of these can be placed in one of the folder locations specified in the developer guide installation instructions.
The add-in manifest includes a tag specifying the location of the add-in DLL.
Remove the path for that, since it is in the same directory, and Bob's your uncle.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 9 of 11
done.. before only.. i had changed guid.
Message 10 of 11
denise.lollar
It was just one file HiltiBIMCADLibraryRevit.exe. This particular one needed the Click2Cad toolbox in order to be accessed after the install. It added in a New tab rather than add it self to the add-In tab.
Message 11 of 11
jeremytammik
If you only have an EXE I cannot help you.
Please contact the add-in vendor for help.
Good luck!
Jeremy
Jeremy Tammik
The Building Coder
