I am trying to export all the active views in a sheet to a single dwg file. I have even set the merge option to true but still it doesn't merge it for me and export the views to different dwg files. it view returns me true once I set it equal to true but still it doesn't merge the views. any help will be appreciated. My code is as below:
Does it work for you manually in the end user interface? What options are you using there? Maybe there is something more that needs to be added?
I can do it manually in the end-user interface. But it doesn't preserve the shared coordinates. Even I select the option in the settings. That's why I tried to do it using the api.
