unable to disable warning for missing third party updater in Revit MEP 2016
I'm using a LiveUpdater in my plugin that causes the warning "missing third party updater" when my clients open the project on their computers since they do not have the plugin installed. I need to disable this and have tried the following to set the LiveUpdater as optional which according to the API documentation should disable the warning:
UpdaterRegistry.RegisterUpdater(liveUpdater, true);
and
UpdaterRegistry.RegisterUpdater(liveUpdater);
UpdaterRegistry.SetIsUpdaterOptional(liveUpdater.GetUpdaterId(), true);
but I'm still getting the warning after "uninstalling" the plugin by removing the plugin .dll and .addin files from C:\Users\mma\AppData\Roaming\Autodesk\Revit\Addins\2016.
during debugging the following call returns true:
UpdaterRegistry.GetIsUpdaterOptional(liveUpdater.GetUpdaterId())
I even tried to use "false" instead of "true" as argument in case I missunderstood the documentation but it didn't work either.
Is this a bug or am I missing something here?
adcdao
Did you find a solution? I'm stuck with the same problem. I'm using Revit 2022.
André
adcdao
Thank you Jeremy, using your solution I was able to remove the updater from my project. But it would be easier if it was possible to revert back the updater to optional. If you set the isOptional parameter to false I wasn't able to revert it back, even using SetIsUpdaterOptional to true. If it's set to true at the beginning, it works, I will avoid the message. A suggestion, this parameter (isOptional) would be mandatory (not optional) so you will have to set it to true of false explicitly.
Thank you,
André
jeremy_tammik
Such a wish for new or enhanced functionality is best directed to the Revit Idea Station
Please search there for a corresponding wish list entry for the suggested functionality and add your comments to it, or create a new one, if none already exists:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensuring that a wish gets as many votes as possible helps underline its importance to you and the rest of the developer community.
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team looks there. Your comment here in the discussion forum might be overlooked.
Thank you!
