UIDocument.Selection.PickObjects
jeroen.vanvlierden
jeroen.vanvlierden
I am using the _uiDocument.Selection.PickObjects method to select multiple elements, but I would like to process them in the order that the user selected them. This order, seems to be random when I get the result from the API
Is there a way of getting the selection order?
Accepted solutions (3)
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @jeroen.vanvlierden ,
Please take a look at the below link
https://forums.autodesk.com/t5/revit-api-forum/revit-api-selected-element-set-order/td-p/5597203
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeroen.vanvlierden
This should work
jeroen.vanvlierden
thanks!
