trying to use application in Revit Macro
jjesusdelpino
Message 1 of 8
jjesusdelpino
Im trying to use the .NewCategorySet() method of the Autodesk.Revit.DB.Creation.Application class.
I dont know how to call this object while in sharpDevelop creating macros because when I type Application, it just automatically goes to an Autodesk.Revit.ApplicationServices.Application object that is not what I want to use.
Any tips about this? Thanks!
Tries this but didnt work.
https://forums.autodesk.com/t5/revit-api-forum/revit-macros-uiapp-and-postcommand/td-p/8222697#
Replies (7)
Message 2 of 8
bhprest
If this:
    Document doc = this.ActiveUIDocument.Document;
    Application app = doc.Application;
did not work, the most likely culprit is that you are using a Document Module instead of an Application Module.
From the Autodesk help website:
How do I access the Application object or the externalCommandData equivalent?All the Application-level macros are associated with the UIApplication object. In application-level macros, the Application keyword pointer in C# and VB.NET returns the API Application object.
In document-level macros, the Document keyword returns the API Document object. To access the UIApplication object from a document-level macro, use this.Application.
 https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Hope this helps!
Message 3 of 8
jjesusdelpino
Hi bhprest and thanks for your anwser! All you tell me seems logic but I still have the same problem. I tried all that but still some errors are raising. I confirm that I am using an application module. According to the Autodesk help website, the "Application" keyword should work for me but as long as I type "Application" this error raise:
            UIDocument uidoc = this.ActiveUIDocument;
            Autodesk.Revit.DB.Document doc = uidoc.Document;
            // UIApplication uiapp = new UIApplication(Application);
            CategorySet CatSet = Application.NewCategorySet();
 - 'Autodesk.Revit.ApplicationServices.Application' doesnt have a definition of 'NewCategorySet'
Its clearly pointing to another Application object. And the thing is, no other approach seems to work for me. I have tried also:
            CategorySet CatSet = uiapp.NewCategorySet();
And the error is:
- 'Autodesk.Revit.UI.UIApplication' doesnt have a definition of 'NewCategorySet'.
Then I also tried:
            CategorySet CatSet = uiapp.Application.NewCategorySet();
And in this case the error is:
- 'Autodesk.Revit.ApplicationServices.Application' doesnt have a definition of 'NewCategorySet'.
Then I also tried:
            //UIApplication uiapp = new UIApplication(Application);
            CategorySet CatSet = this.Application.NewCategorySet();
Its a bit confused but I think I have tried every single posibility according to my knowledge here. I think Im missing something but I dont know what is. I believe that the first way is the one that should work according to what I see in the help site.
Thanks you so much for your anwser. Regards
Message 4 of 8
FAIR59
try:
this.Application.Create.NewCategorySet();
Message 5 of 8
so-chong
As Fair59 suggest
is equivelant to
Application app = this.Application;
CategorySet CatSet = app.Create.NewCategorySet();
Hope this helps
Message 6 of 8
stever66
I don't get that to work in a DOCUMENT level macro.  (I'm using Revit 2020.  One of the previous replies referenced 2016. )
According to the help, Document.Application refers to the Application object in a document level macro.
This seems to compile:
Document.Application.Create.NewCategorySet();
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-C6E0196D-918B-4131-9B64-050DBE452158
Message 7 of 8
so-chong
Hi @stever66 ,
You are right about a Document level macro your code snippet is the way to go.
Though i thought the orginal poster of this thread said something about....."I confirm that I am using an application module".
So my snippet of code will only work in Application level macro.
I hope the orginal poster can clarifies which level( application or document ) the code is intended to be used or show more of his code where the error occurs.
Message 8 of 8
jjesusdelpino
Hi all and thanks for your anwsers. I finally manage to solve this as FAIR59 said. To clarify some doubts around this post. Im working on an application module and what I learned here is.
            Autodesk.Revit.ApplicationServices.Application app = this.Application;
            Autodesk.Revit.Creation.Application app1 = app.Create;
And then either:
            or:
            CategorySet CatSet = app1.NewCategorySet();
The conflict came when Application can refer to either Autodesk.Revit.ApplicationServices.Application or Autodesk.Revit.Creation.Application. In this case I needed the Creation one to create the CategorySet but you will obviously have to understand both depending on your code. For example, later in the same code I need to use Autodesk.Revit.ApplicationServices.Application.OpenSharedParameterFile() so I have to use "app" there. Hope this helps and Thanks you all for your anwsers 😃
