Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
trying to use application in Revit Macro
jjesusdelpino
jjesusdelpino
Im trying to use the .NewCategorySet() method of the Autodesk.Revit.DB.Creation.Application class.
I dont know how to call this object while in sharpDevelop creating macros because when I type Application, it just automatically goes to an Autodesk.Revit.ApplicationServices.Application object that is not what I want to use.
Any tips about this? Thanks!
Tries this but didnt work.
https://forums.autodesk.com/t5/revit-api-forum/revit-macros-uiapp-and-postcommand/td-p/8222697#
Replies (7)
bhprest
If this:
    Document doc = this.ActiveUIDocument.Document;
    Application app = doc.Application;
did not work, the most likely culprit is that you are using a Document Module instead of an Application Module.
From the Autodesk help website:
How do I access the Application object or the externalCommandData equivalent?All the Application-level macros are associated with the UIApplication object. In application-level macros, the Application keyword pointer in C# and VB.NET returns the API Application object.
In document-level macros, the Document keyword returns the API Document object. To access the UIApplication object from a document-level macro, use this.Application.
 https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Hope this helps!
jjesusdelpino
Hi bhprest and thanks for your anwser! All you tell me seems logic but I still have the same problem. I tried all that but still some errors are raising. I confirm that I am using an application module. According to the Autodesk help website, the "Application" keyword should work for me but as long as I type "Application" this error raise:
            UIDocument uidoc = this.ActiveUIDocument;
            Autodesk.Revit.DB.Document doc = uidoc.Document;
            // UIApplication uiapp = new UIApplication(Application);
            CategorySet CatSet = Application.NewCategorySet();
 - 'Autodesk.Revit.ApplicationServices.Application' doesnt have a definition of 'NewCategorySet'
Its clearly pointing to another Application object. And the thing is, no other approach seems to work for me. I have tried also:
            CategorySet CatSet = uiapp.NewCategorySet();
And the error is:
- 'Autodesk.Revit.UI.UIApplication' doesnt have a definition of 'NewCategorySet'.
Then I also tried:
            CategorySet CatSet = uiapp.Application.NewCategorySet();
And in this case the error is:
- 'Autodesk.Revit.ApplicationServices.Application' doesnt have a definition of 'NewCategorySet'.
Then I also tried:
            //UIApplication uiapp = new UIApplication(Application);
            CategorySet CatSet = this.Application.NewCategorySet();
Its a bit confused but I think I have tried every single posibility according to my knowledge here. I think Im missing something but I dont know what is. I believe that the first way is the one that should work according to what I see in the help site.
Thanks you so much for your anwser. Regards
FAIR59
try:
this.Application.Create.NewCategorySet();
so-chong
As Fair59 suggest
is equivelant to
Application app = this.Application;
CategorySet CatSet = app.Create.NewCategorySet();
Hope this helps
stever66
I don't get that to work in a DOCUMENT level macro.  (I'm using Revit 2020.  One of the previous replies referenced 2016. )
According to the help, Document.Application refers to the Application object in a document level macro.
This seems to compile:
Document.Application.Create.NewCategorySet();
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-C6E0196D-918B-4131-9B64-050DBE452158
so-chong
Hi @stever66 ,
You are right about a Document level macro your code snippet is the way to go.
Though i thought the orginal poster of this thread said something about....."I confirm that I am using an application module".
So my snippet of code will only work in Application level macro.
I hope the orginal poster can clarifies which level( application or document ) the code is intended to be used or show more of his code where the error occurs.
jjesusdelpino
Hi all and thanks for your anwsers. I finally manage to solve this as FAIR59 said. To clarify some doubts around this post. Im working on an application module and what I learned here is.
            Autodesk.Revit.ApplicationServices.Application app = this.Application;
            Autodesk.Revit.Creation.Application app1 = app.Create;
And then either:
            or:
            CategorySet CatSet = app1.NewCategorySet();
The conflict came when Application can refer to either Autodesk.Revit.ApplicationServices.Application or Autodesk.Revit.Creation.Application. In this case I needed the Creation one to create the CategorySet but you will obviously have to understand both depending on your code. For example, later in the same code I need to use Autodesk.Revit.ApplicationServices.Application.OpenSharedParameterFile() so I have to use "app" there. Hope this helps and Thanks you all for your anwsers 😃
