Trying to create an electrical system
Hello everybody,
I am here maybe with a stupid question,
I am trying to create an electrical circuit via the revit API. I have see that there are not many examples on how to do it.
I have seen in the revit API help the referece to the "NewElectricalSystem" Method (http://revitapisearch.com/html/654da57c-4209-f64d-5f4f-8635c4708f98.htm) and I am trying to do it with the next code:
     FamilyInstance eLoad = doc.GetElement(subCompId) as FamilyInstance;
    ConnectorSet cS = eLoad.MEPModel.ConnectorManager.Connectors;
    foreach(Connector c in cS)
        ElectricalSystem nES = Autodesk.Revit.Creation.Document.NewElectricalSystem(c,ElectricalSystemType.PowerCircuit);
It seems easy, but unfortunately y get the next error:
An object reference is required for the non-static field, method, or property 'Autodesk.Revit.Creation.Document.NewElectricalSystem(Autodesk.Revit.DB.Connector, Autodesk.Revit.DB.Electrical.ElectricalSystemType)' (CS0120)
And I have no idea on how do i have to proceed in order to fix it.
Can anyone give any help??
many tanks in advance!
JimJia
hi,
Please replace Autodesk.Revit.Creation.Document.NewElectricalSystem with doc.Create.NewElectricalSystem.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Perfect!!
Thanks a lot!
